Hi, brand new here, and not sure if this the right place post this, but please tell me if not. I stumbled upon this place in my search to find out if I can find a way to make my Toshiba HD-A2 dvd player play PAL discs. I have a bootleg(not copywritten material) from the UK that plays on my computer, but not on my Denon DVM-1815 or my Toshiba HD-A2. I found this, and I've never done this, so am a little leery, but figured I'd see what kind of feedback I got on it. What I'm getting out of this is the first firmware shown converts the player to the European version, which supposedly plays PAL, and the second one makes it region free, which isn't my biggest concern. My concern is how risky is this? Obviously you run the risk of the player not working after this, correct? Or, is there a way to bring it back if you screw up. I got this player at some black friday sale at WalMart for $85 but still, I don't want to ruin it just to watch a PAL disc here and there. If anyone thinks the odds are that it will work out fine, then I may take the chance, but I'd like to hear from some people that like to mess with their equipment quite a bit to see if it's worth a try. I'm assuming all I'd have to do is follow these directions . Any advice or feedback at all greatly appreciated. Thanks in advance!
EDIT: After browsing around a little, I discovered that this post fit much better in the 'DVD & Blu-ray Players' section, so I posted it there also. Not sure if that is a rule breaker here but, if so, can a mod or anyone who has the power, delete this post? Thanks!
Newbie needs help with getting burned discs to play on dvd player.
By Takeonelastbreath in forum Authoring (DVD)Replies: 1Last Post: 22nd Sep 2010, 15:02 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
Newbie, and considering hacking Toshiba HD-A2 to play PAL discs
By Puppets86 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 7th Jun 2008, 18:30 -
Will a US HD-A3 Play HD Pal discs ?
By ofield1 in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2008, 15:01 -
Hacking the Toshiba RD-KX50 or just getting past Mircovision
By gbann123 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th May 2007, 23:54
