My dvd plays fine on a computer but the sound is all muzzled on a dvd player.I tried to convert the sound file AC3 into a MP3 and enhance the audio but still no joy.Any suggestions?
Give us more information!
Is it a dvd-video(vob,ifo,bup) or avi with ac3/mp3 audio? or something else? -
DVD video won't work with MP3 audio. Your AC3 should have worked, unless your AC3 is out of specification. How did you create the AC3 audio? What program or method? You could try MPEG-1 Layer2 audio or WAV or PCM audio, but the audio file will be huge with a WAV file.
DVD audio specifications:
This is from 'WHAT IS' DVD to the upper left on this page.Audio:
48000 Hz
32 - 1536 kbps
Up to 8 audio tracks containing DD (Dolby Digital/AC3), DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio. -
The answer at this point is real simple. You need to make it sound better.
Now, did you find that annoying? How about enlightening us as to -
What You Started With?
What You Have Now?
How You Got There?
Or, if you'd just rather have a wild guess with no information whatsoever to go on, then try rubbing the disk counterclockwise on an albino monkey's butt.
Whats a simple software DVD player that just works !
By Bansaw in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2011, 16:20 -
trying to fix a scratched dvd, works on pc but not player...
By extent in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 10:02 -
Problem with surround sound. Works why Im playing the TV but not with a DVD
By marionr26 in forum AudioReplies: 3Last Post: 15th Feb 2010, 18:28 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 03:54 -
my dvd-lo that works on Mac, not in external player
By oldblues in forum ffmpegX general discussionReplies: 8Last Post: 11th Jul 2007, 04:22
