Results 1 to 9 of 9
    Jun 2008
    I see this is a trial version, any idea where I can get a freeware version????
    Oct 2005
    666th portal
    the tool page has the old freeware version. it used to be divxtodvd. not quite as good as the new one. use the new version's trial and if you like it, buy it. all-in-ones don't get any better than it.
  3. ConvertXtoDVD is not freeware.
    Jun 2008
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Unless you need something very specific to ConvertXtoDVD, FAVC provides a superior encoder at the cost of speed, and DVD Flick allows for joining multi-part titles. Both are free and worth checking out.
    Read my blog here.
  6. Member steptoe's Avatar
    the new ConvertXtoDVD v3.xx supports avisynth scripts, but I'm still trying to get a decent reply as to how good the support for avisynth scripts are as I use soem very complex filter chains and functions, all I get it yes avisynth do work and thats from the so called moderators on convertx forums
    Jun 2008
    SCRIPTS! OMG I know nothing of them so I sure would be lost
  8. Member Seeker47's Avatar
    Jul 2005
    I tried the old divxtodvd and was rather underwhelmed by it. ConvertX is much better . . . though I probably would not have purchased it were it not on sale at the time. I was a bit surprised to find out that it apparently owes a huge debt to FFMPEG, which is free, and I've since read something about some other conversion tool (besides the ones mentioned in this thread so far) that is also free. Can't recall the name at the moment, but the author posts to VH from time to time..
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
    Jun 2008
    Thanks again for the responses
