does anyone know any kinds of software that can fax on the pc directly to the fax machine without modem and telephone line , using the networking?
http://www.kiva.org/about -
thank you for the link, but this isn't what i want, i wants something that can fax out without a modem card and telephone line.Originally Posted by edDV
Cannot be done.
Fax is an analogue service. There is no way that can be transmitted by a digital regime.
There are companies who offer a work around and you send the message via email which they convert to a standard fax AT A COST -
And fax over internet kind of defeats the purpose of the format.
I have used a fax program with my laptop modem called 'Mighty Fax' for quite a long time. It's shareware, but you only pay once for lifetime upgrades. http://www.rkssoftware.com/mightyfax/overview.html It's very easy to use and you can use it on several computers under the same license.
It can fax documents from a scanner or from a word processing program and also receive fax transmissions. BTW, many word processors can output a simple fax. Instead of printing, you just send the document to the fax 'printer'. (The modem.) You need a fax driver, though.
In order to use a internet fax, the fax you send digitally has to be converted to analog and the destination phone fax machine dialed. That's the cost. Though there may be free options out there.
If you want to use the internet to send a document, a email attachment would be simpler.
I convert to Adobe PDF format for that, then what you send is what they get.
Kind of but if you have to get a document through to someones fax machine or they need to send it to you from one - well, kind of handy then.Originally Posted by redwudz
Chris Haycox
Metro Hi Speed offering reliable internet fax services to businesses of all sizes. Convenient, affordable and reliable - visit us today. -
If you have a networkable fax machine, then it would have come with the necessary software.
PC fax modem less than $20.00 now. Also, there is Kinko's or similar office supply co. -
I'm still trying to grasp this concept.Originally Posted by metrofax
Faxing is a (mostly) outdated technology. Email or file transfer is pretty much the standard.
Most laptops come with a modem (probably the manufacturers being nostalgic). Windows has built in faxing that is more than adequate for that (antiquated) technology.
Is there 2 kinds of AVI extensions?
By jbitakis in forum Video ConversionReplies: 7Last Post: 24th Nov 2011, 12:32 -
What software do they use to make these kinds of videos?
By kite88 in forum Newbie / General discussionsReplies: 10Last Post: 10th May 2010, 02:16 -
I'm confused by different kinds of the same disc ID
By JohnnyBob in forum MediaReplies: 7Last Post: 9th Feb 2010, 18:50 -
anyone here use online fax service?
By lordhutt in forum Off topicReplies: 3Last Post: 18th Jul 2009, 16:11 -
Question about 2 different kinds of proxies
By jimdagys in forum ComputerReplies: 7Last Post: 28th Apr 2009, 05:53
