What kind of file is a Soundslide project? There seem to be some jpegs in there and something with the ending ssl. What would I use to convert this into a DVD?
Have you tried download soundslide, http://www.soundslides.com/ (trial available) and see if you can open the project and export to some video format?
That's just what I'm trying to do, I opened one of my projects, but I can't figure out what the file endings mean.
Found this as desciption for the file extension:
http://www.wotsit.org/list.asp?search=ssl&button=GO%21
EDIT: Forget about the file extension. The search was catched on losSSLess.
"Corel Flow Smart Libraby" is mentioned somewhere else and Borland also seems to use the extension.
The site says: Soundslides exports Adobe Flash files (SWF). Perhaps you can convert this to mpeg2 for DVD ?
If the trial allows to export this would be the easiest.
Conversion help.
By yugub in forum Video ConversionReplies: 9Last Post: 18th May 2011, 21:45 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 19:36 -
.TS or .TP conversion
By joepic in forum DVB / IPTVReplies: 4Last Post: 22nd Jan 2009, 14:22 -
2.35:1 conversion to 1.85:1 (or 1.77:1)
By mgarrido in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2007, 00:21
