My camera captures in an mp4 format that is unreadable by final cut pro. These clips are in 720p. I have played around with visualhub, ffmpegx, and mpeg streamclip trying to find the best setting.
Converting to DV downscales the video, but is fairly quick.
Converting to xvid diminshes the quality, but is failry quick.
Converting to quicktime takes forever and produces enormous files.
Converting to mpeg2 or mpeg4 with h.264 works okay, but FCP has a hard time handling these files quickly (ie I can't even use the jog dial)
So which is it? What would you do?
Results 1 to 14 of 14
I'm not sure what type of camera it is, but it doesn't offer any other formats. Even if it did, I need to work with the footage I have now and can't exactly re-record it.
Our main camera is a Sony HDR-FX1 - and it has worked beautifully. No problems there. We had to use this other little handheld thing in a pinch as our B Cam.
The compression I used in mpeg streamclip is called "Apple Motion JPEG A." I tried a few others (there's a whole slew of them in the drop down menu), but this seemed to be the fastest. Even so, it took about 12 hours to convert a 20 minute clip and it ended up being 20x the size of the original.
What is the apple intermediate format? I tried searching around a bit to find out more, but wasn't able to come up with anything. -
You should junk your "B" cam and replace with a FCP compatible model. Used HC1,3,5 or Canon HV20 are now under $500 on Craigslist or ebay if you bid with skill.Originally Posted by sam1amRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I agree, but right now I have the footage that I have and I need to work with it.
Have you yet provided ID for camcorder in question? Do you have a PC for utilities?Originally Posted by sam1amRecommends: Kiva.org - Loans that change lives.
I'm guessing the cam is a Sanyo Xacti. Been tempted, but worry about the editing tweaks required.
I support rumplestiltskin's observation above.
Back up and sort out your priorities.
You're trying to edit, right? And you're using FCP (on a Mac, of course). So, unless you can Dualboot or VM, your choices are somewhat limited.
Do you want QUALITY? If so, you should be less concerned with "BIG FILE SIZES". Save to Apple Intermediate Format, ProRes, DNxHD, Cineform or some other nearly-lossless, or lossless, or uncompressed format. If you were doing SD, you could do DV, DVCPro50, or MJPEG, but it's clear from your 1st post that you would be "downscaling" so you must be starting with HD material and it would be a shame to downscale it prior to getting to your final master. The time for downscaling is as a special output for SD viewing.
Would sure help if you told us the model you're using...
Scott -
MP4 is a final delivery lossy video format which is not suitable for editing in non-destructive video editing software like Final Cut Pro.
Apple ProRes is an ideal format for Final Cut Pro.
I use iDealshare VideoGo which can easily convert all kinds of MP4 videos to FCP, FCP X, FCE supported Apple ProRes, MOV or DV.
Besides converting MP4 to FCP format, iDealshare VideoGo also helps to convert other video formats like MOV, WMV, AVI, MKV, VOB, AVCHD, MXF, MOD, TOD, RMVB, 3GP, FLV, ASF, SWF and etc to Final Cut Pro supported video format.
Just google search Step by Step Guide to Convert MP4 to Final Cut Pro with iDealshare VideoGo, you will find a detailed guide.
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
Final Cut Pro Movie to x264 mp4
By skywriter in forum ffmpegX general discussionReplies: 0Last Post: 8th Feb 2010, 15:19 -
16:9 in Final Cut Pro
By malibu in forum MacReplies: 2Last Post: 5th Jul 2008, 09:41 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05 -
Final Cut Pro / Soundtrack Pro Link Problem
By scottrwn98 in forum MacReplies: 11Last Post: 1st Jun 2007, 11:36
