I need to know if anyone knows of a piece of software that does what I need. I need it to take a bunch of wmv clips and mix them together with background music and the ability to some text to the screen. Basically I am trying to make a music video, but can't find the software to do what I want. Any suggestions? Thanks.
	There are many editors, it depends what format you want to end up with.
 Look under "LISTS/Tools", left side of this page. Lots of choices.
	I just want to end up with a wmv file, if that's what you mean. Thanks.
	What I mean is, you want to be able to play it on DVD player or just on computer?
	Windows Movie maker is already on your machine and is built specifically for editing WMV videos. Read my blog here.
	Just on the computerWhat I mean is, you want to be able to play it on DVD player or just on computer?
	Listen to guns1inger. Use Windows Movie Maker. Newer thought of that one since I deleted it from my machine.
	I certainly agree with you. Her suggestion is really helpful.Originally Posted by tinker
  Video Editing SoftwareBy Cooldown in forum Newbie / General discussionsReplies: 6Last Post: 22nd Apr 2012, 13:17
  Video editing software that supports importing video with multiple audio?By elgy in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2011, 20:32
  Video Editing Software: mkv, h264 & DTS Editing?By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29
  Video Editing Software: Which is the best for what I am trying to do?By pcnes in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2011, 21:11
  video editing softwareBy malakov08 in forum MacReplies: 3Last Post: 27th Sep 2009, 10:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
