I need to convert some files to flv
what are the differences between those codecs, how to decide which one is better to use
H.264 or On2 VP6
is it true that H264 requires flash 9 and that may be too heavy for older machines to decode?
is it H264 really that much better (quality/file size ratio) that its worth it to accept those two disadvantages? -
yes you need flash9, yes it's heavy.
at reasonable frame dimensions it shouldn't tax much.
that much better than vp6?
i don;t think so,
I quite like vp6.
try it for yourself.
the only/best way.
take your specific content,
encode both ways and see...
tripp -
ok its decided, im gonna use vp6, but here is something else
is 16:9 aspect ratio supported by this codec? Since i didnt find that option in all the software i tested
if its not, is resizing 16:9 720x576 raw avi to 1024x576 flv gonna do the job ok?
Good Blog on why Google wanted On2
By ahhaa in forum Software PlayingReplies: 0Last Post: 13th Aug 2009, 10:16 -
On2 VP7 Personal edition
By runLoganrun in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2008, 15:18 -
Vp6 format
By branch in forum Newbie / General discussionsReplies: 0Last Post: 4th Nov 2008, 19:02 -
vp6 hell
By Mark69 in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 20:37 -
Cant get On2 Flix programs to start
By ricardouk in forum Video Streaming DownloadingReplies: 1Last Post: 13th Jul 2008, 16:19
