I am using Sony Dvd Architect 4.5, I also have FAVC, DVDFLick, and IMGBURN. I want to burn a dvd of my friends daughters performance. I would also like to include a couple videos for the phone, or computers. I would like to put it all on one disc. Just curious how to do this. Thanks
Jensen
HV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850
Create your DVD as normal so you have your video_ts folder and audio_ts folder. At the same level as these, create a new folder called Extras (or whatever you like) and put extra files in here. When it comes time to burn the DVD, open Imgburn and select Write File/Folders to Disc. Browse for a folder and select the Video_TS folder first. This tells Imgburn that you are burning a DVD Video disc. Now browse for the Extras folder. Burn the disc as normal and test. The Extras folder will be ignored by standalone players, but be visible and accessible on a PC/Mac/Linux box
I would produce the Extras first so you know how much space you need during authoring.Read my blog here.
Your saying use img burn (build mode) to put the extras folder in? Or DVD Architect? I dont think space will be a problem considering the mpeg2 clip is only 6 mins long. Im assuming I cant take mpeg2 + ac3 and make vts folders?
HV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850 -
Author your DVD with DVD Architect (or FAVC - whatever works for you), and output the DVD structure to your HDD. This will give you your Video_TS folder, and perhaps the Audio_TS folder, although it is no great loss if it is missing. Then create your Extras folder in Windows Explorer, then burn the lot with Imgburn.
Read my blog here.
Makes sense... Thank you. When I make the extras folder do I put it in the vts folder? Or when I build just include it?
success !! Thank you, that was easier than I thought.
Bluray to dvd ( include menus )
By pcb in forum Blu-ray RippingReplies: 7Last Post: 26th Apr 2010, 20:35 -
Question about how to include software on authored DVD
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 28th Sep 2008, 19:47 -
How to include a 320x256 size video in a DVD
By dvdnewb2 in forum EditingReplies: 3Last Post: 18th Aug 2008, 08:19 -
Only converting first chapter on DVD (videoTS&RM).. how do I include al
By Toriat100 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2008, 11:24 -
WMV to DVD compliant MPEG2 - TDA3 or DVD Maker - what is the right way?
By MagicSparky in forum Video ConversionReplies: 5Last Post: 23rd Aug 2007, 12:27
