First, I am currently trying to find an Encoder that is similar to CCE. CCE is the only encoder that I have used and I would like to have an alternative if CCE just can't handle a file, which seems to be the case lately.
I would like something that:
1) Accepts AVS files
2) Can do a pulldown
3) Does batch encoding
Today, I spent some time testing Avanti as it uses FFMpeg but I just couldn't get it to work.
Second, I just had some questions about FFMPeg.
Could someone provide me with a basic command line example that accepts an AVS file as input (video is MP4), has average or above average video quality and renders an MPEG-2 compliant file for DVD?
I have looked at the FFMPeg guides, but would like to get decent feedback from the forum.
I actually have more questions but I am in a hurry and will the others later.
Results 1 to 30 of 86
You are probably going to get a lot of recommendations for HCenc. It can do everything in your list of wants. Batch encoding is accomplished via command line. If commandline does not suit you there are a some different gui that offer batch encoding through hcenc.Originally Posted by Maikeru-sama
Small list
FAVC
avstodvd or is it avs2dvd (not sure)
hc_batch.exe by mikeytown2
or my very own HCbatchGUI
There may be others but that's all I can think of off the top of my head. Try them all and see what works the best for you. They are all freeware. If you try my hcbatchgui and have any suggestions you can leave them on the development page in the programming forum here on videohelp. There is a link to it in the program itself.Donadagohvi (Cherokee for "Until we meet again") -
Thanks for the suggestions. I downloaded HC Encoder and HC BatchGui and I will be playing around with it for the next few days.
In the HC BatchGui, is there a way to tell the program which file extensions to look for? It just has a Source Directory, so I am assuming it is going to process every valid video file in there correct?
It just looks for d2v, avi, and avs.
I basically made it to process DV avi's and downloaded xvid/divx avi files.Donadagohvi (Cherokee for "Until we meet again") -
HCenc or just HC for short is a great encoder. In fact I would say that it is almost as good as CCE over all and in some instances even better. Only thing I don't like is that it cannot really do a true CBR encode.
Please note that in the past the auto GOP setting for NTSC didn't really work well so it was better to set it manually although I think that has since been sorted out.
Freebird, quick couple of questions about the HC Batch Gui:
1) Is there a way to disable the audio? I am use to disabling the audio via Avisynth and then using FFMpeg to work on the audio. Obviously, I can change my mode of thinking but I wouldn't mind having that option.
2) How do you stop the program
? I got an error stating that the program could not handle parameter "-b" but it kept processing the audio and I couldn't stop it.
3) If I am loading AVS scripts, I am assuming the destination size has to be in the AVS script or I have to use the AVS generator in HC Batch Gui?
BTW, I am referencing your guide here:
https://forum.videohelp.com/topic337887.html
Edit:The error is: "can't process parameter -b" -
One other question, is there a way to change the names of the files rendered?
Disregard all questions, as I think I have the hang of the program.
As far as the audio naming conventions, I will just go into the batch file and change that myself or something as I need it to be the same name as the m2v file. -
Actually I am going to add the ability to customize the avisynth script in the next windows release. I have already added those feature to my linux release.Originally Posted by Maikeru-sama
The audio in hcbatchgui is processed by aften which is based on ffmpeg. If you really want to use ffmpeg to process audio just leave the audio tab blank.
HCbatchgui uses an independent application called psshutdown to Abort the working processes. You will have to press "abort the process" at least once and accept the license agreement before it works. Just look at the bottom of the start process page for the Abort process button.2) How do you stop the program
I'm assuming you mean the final video output size then no. You need to set the average and maximum bitrate on the first tab.3) If I am loading AVS scripts, I am assuming the destination size has to be in the AVS script or I have to use the AVS generator in HC Batch Gui?
You will get this error if you don't set the bitrate values.Edit:The error is: "can't process parameter -b"
I should probably change that so the audio should be the same as the video name by removing the HCaudio prefix.One other question, is there a way to change the names of the files rendered?
This little proggy is really just a simple little gui that creates the batch script for you. You could alter the batch script by aborting the process then changing the batch file in a text editor.
edit- just saw that you figured things out. If you have any other questions or suggestions please let me know. I try to implement features and suggestions into the proggy if my "limited" programing skills will allow it.
Happy encoding.Donadagohvi (Cherokee for "Until we meet again") -
DOS question for everyone.
Problem - If I have a file called: "mymp4.mp4.avs", The command line below will render a file called: "mymp4.mp4.avs.m2v". I would like to remove the "avs" from the string before it is rendered.
<DOS>
for %%a in ("*.avs","*.d2v") do "C:\HCenc_023.exe" -i "%%a" -o "C:\%%a.m2v" -b 3000 -maxbitrate 8000 -ini "C:\HC.ini"
</DOS>
Is there a way to
1) Place %%a into a variable
2) Use a string manipulation function like replace to remove unwanted portions of the string and then call HCenc
I will continue to research the Internet but wanted to ask here as well. -
Thanks Tripp, I will try this out.Originally Posted by 45tripp
The numbered list was just an extension of what I was asking at the beginning of my last post. I just don't want "avs" in the rendered file. -
45Tripp, it worked like a charm and you just saved me a ton of work as I was about to try and accomplish the same task through a VB.net form.
Thanks -
Maikeru-sama wrote:
There is *no* actual DOS under any Win32-environmentDOS question for everyone.
(Windows 95/98/ME included).
Thanks for that completely useless and condescending postOriginally Posted by Midzuki
freebird73717 or anyone else with knowledge of the "wavi.exe", is there a way to map audio with this tool or would I have to do it in Avisynth?
For example, if I had an MKV file with dual-audio, is there a way to choose which audio I want the program to use, which would be similar to the "map" argument in FFMpeg.
I will continue to research if this could be done in Avisynth. -
wavi only uses uncompressed audio from an avi or audio from an avs file (since avisynth decompresses the audio for you).
Not sure if you can do what you want in avisynth or not. I've never tried. You probably can though because avisynth is a very powerful tool.
Good luck!Donadagohvi (Cherokee for "Until we meet again") -
not unless you use ffmpegsource()
with atrack
so,Code:ffmpegsource("blah.mkv", atrack=?)
tripp -
Maikeru-baka wrote:
I agree --- correct information is always "useless", "condescending" andThanks for that completely useless and condescending post
(more importantly) "irrelevant". On the other hand, the proud of remaining
uninformed and misinformed is always "cool".
@freebird73717, any idea why HCenc crashes when I choose to place the "AVSReload" option in the INI file? Not sure what this does, but the tooltext says that it helps prevent "source mismatch errors", which I am getting alot of according to HCenc, but maybe that is normal?
@Everyone, I am getting what you call "flashy" (not jerky) video using HCenc through the command line using an INI file. My MP4 is "Progressive" and for the "Interlaced Options" I have chosen both "auto" and "progressive" and I am getting the same "flashy" type video.
Quenc rendered the same file perfectly although the output was way larger than what I expected, but that is for another day.
Here is some background info:
<AVISYNTH>
DirectShowSource("C:\myvideo.mp4", audio=false)
LanczosResize(640,440,4,0,1272,720)
AddBorders(40,16,40,24)
ConvertToYV12()
</AVISYNTH>
<INI>
*MATRIX mpeg
*BITRATE 3000
*MAXBITRATE 8000
*PROFILE best
*DC_PREC 10
*SMP
*PULLDOWN
*ASPECT 4:3
*PRIORITY normal
</INI>
<MEDIAINFO>
General #0
Complete name : C:\myvideo.mp4
Format : MPEG-4
Format/Info : ISO 14496-1 Base Media
Format/Family : MPEG-4
File size : 175 MiB
PlayTime : 23mn 24s
Bit rate : 1047 Kbps
StreamSize/String : 573 KiB
Encoded date : UTC 2008-03-09 08:49:28
Tagged date : UTC 2008-03-09 08:49:28
Video #0
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec profile : High@L5.1
Codec settings, CABAC : Yes
Codec_Settings_RefFrames : 16
PlayTime : 23mn 24s
Bit rate mode : VBR
Bit rate : 926 Kbps
Maximum bit rate : 6712 Kbps
Width : 1280 pixels
Height : 720 pixels
Display Aspect ratio : 16/9
Frame rate mode : CFR
Frame rate : 23.976 fps
Chroma : 4:2:0
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.042
StreamSize/String : 155 MiB
Encoded date : UTC 2008-03-09 04:53:53
Tagged date : UTC 2008-03-09 08:49:32
Audio #0
Codec : MPEG-1 Audio
Codec/Family : MPEG-A
PlayTime : 23mn 24s
Bit rate mode : VBR
Bit rate : 118 Kbps
Maximum bit rate : 148 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
StreamSize/String : 19.7 MiB
Encoded date : UTC 2008-03-09 08:49:31
</MEDIAINFO> -
no, it's not normal.Originally Posted by Maikeru-sama
but people do have a problem with it.
personally i've not.
avsreload is an option to clear the memory of the avisynth script to avoid the mismatches, or potential crashes.
one solution to frame mismatches is to use the losseless inermediate file option in 0.23
that resize seems wrong.Originally Posted by Maikeru-sama
post a screenshot of source.
meaning?Originally Posted by Maikeru-sama
post a small sample clip exhibiting this 'flashy' behaviour.
tripp -
@45Tripp, I forgot to mention that when I do "lossless", HCenc crashes as well. Below is the error being reported when it crashes:
<HCENC LOSSLESS>
AppName: hcenc_023.exe AppVer: 0.23.0.0 ModName: hcenc_023.exe
ModVer: 0.23.0.0 Offset: 0001153c
</HCENC LOSSLESS>
I will upload some images of what I have described as "flashy" playback once I re-encode as I have already deleted the file. Also, "flashy" may be a bad term, when I look at the video in TMPGenc DVD Author one frame at a time, in blocks of the video, every other scence seems to have horizontal lines going through the video and of course when you play the video its seems like it is "flashy" because of the scenes with lines on them.
Also, the Avisynth script was generated through FitCD, which has always been accurate to my knowledge. -
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
FFMPEG Prores Encoder?
By Guiboche in forum Video ConversionReplies: 19Last Post: 11th May 2012, 16:40 -
Which is the best encoder? FFmpeg? staxrip, or megui?
By Vlenbo in forum Video ConversionReplies: 7Last Post: 14th Dec 2008, 23:08 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
Basic FFMpeg Questions
By Maikeru-sama in forum Video ConversionReplies: 8Last Post: 7th Jun 2008, 09:33
