Hey all,
My Task Manager has lost it's GUI. No more buttons!!
When I want to close it I have to use Alt+F4 and to move between tabs I have to use Ctrl+Tab.
Minor, I suppose, but I'd really like it to work properly.
If the old lady were to open it for whatever reason, she'd be totally lost.
Any ideas?
TIA!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Double click on the tiny border around the window.
When you open up Task Manager in Windows XP, there is no title bar, menu bar, or program tabs showing. Only the running applications, End Task, Switch To, and New Task buttons show up.
This problem is easy to fix, the Task Manager is running in "tiny footprint mode". To correct this, simply double-click on the border around the window and it will return to its normal state. To place task manager back in "tiny footprint mode" again, double click again on the border around the window. -
you're awesome! where did you find that?
Some fool called xylob has been installing sTarDock windowing software.
erm...
No.
What the hell is that? Had to google it -- looks like utter stupid crap.
If you're referring the the StarWindService.exe process that I have running, it's part of Alcohol 120% to provide network drive sharing capabilities for that program.
Nice try though, fool."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
Oh, well, it worked for me on Windows 7 Ultimate 64 Bit.
Good thing your search is working well too.
Thanks guys.
John
iexplore/task manager problem
By mysts in forum ComputerReplies: 2Last Post: 6th Jul 2009, 23:24 -
Task Manager has disappeared
By mysts in forum ComputerReplies: 12Last Post: 6th Apr 2008, 08:51 -
eSATA strangeness
By piano632 in forum ComputerReplies: 5Last Post: 3rd Apr 2008, 10:09 -
Task Manager -- items which can be safe to remove without it rebooting.
By vhelp in forum ComputerReplies: 14Last Post: 1st Apr 2008, 11:49 -
[solved, kthx]4GB of RAM not recognized in XP Home SP2
By doomdoomdoom in forum ComputerReplies: 2Last Post: 11th Dec 2007, 04:04
