Hi, I always use DVD Decrypter 3.5.4 to burn my DVDs and rip my DVDs. I usually use ISO Read mode to rip them, but I have heard there are advantages to using File mode. What are these advantages and do I have to change anything in the settings (I always just use the default settings)? Thanks!
Results 1 to 10 of 10
I wouldn't change what you are doing. I'm going speculate here.
Possible advantage of file mode open - If a disc error causes a VOB you don't really care about anyway to fail to copy, you can skip around it and then use something like VOBBlanker to get rid of it. Ripping in ISO mode is "all or nothing".
Possible disadvantage of ripping in file mode - It's best to have 32k gaps between BUPs and IFOs. If you rip in file mode, you have to recreate this by hand. See a discussion of why this is important and how to do it here:
http://www.digital-digest.com/~blutach/pgcedit_guide/burning_with_pgcedit/burning_with...pgcedit_v2.htm
Ripping in ISO mode should in theory preserve this gap, assuming that the original DVD was created with such. It should have been, but nobody seems to know how to check prior to ripping. I've asked about it before to know if there is a way to check on this and nobody ever replied with a way to do it. -
there are advantages as to what you can do with the files.. for example, you can play DVDs from your HDD through Vista Media Center or with PowerDVD, whereas you can't with an .iso. also if you intend to manipulate the files with other software, you typically need the actual 'files' (.VOB and .IFO files) rather than an .iso
I am just a worthless liar,
I am just an imbecil -
You can play ISO files directly with VLC. You can also play ISO files with any video player that can play DVDs by mounting the ISO with Daemon Tools or Nero Drive Image. Using a HTPC, like Meedio, you can have it automatically mount ISO video files and play them with your favorite video player.Originally Posted by TooLFooL
Thanks,
jawgee -
Yeah, I didn't think about that. No shrinking or eliminating unwanted parts of the DVD (ie. foreign language soundtracks, extras, etc.) if you have an ISO.Originally Posted by SingSing
If you rip a problem DVD in ISO mode and there is a problem with the rip, you need to begin all over again. In file mode, the problem may just be in part of 1 vob and you can see where it is. Then you can just work with that vob using a number of extraction programs. Also, lots of times when DVD Decrypter is working with 1 file, it seems to extract better.
Tony -
Quite a few programs don't read from ISO files, so you have to mount them to get to the content.
As for the 32kb gap - if you burn with Imgburn (DVD Decrypter's younger but smarter brother) it will put these in place for you, so file mode isn't so bad any more.Read my blog here.
Thanks for all the replies guys! I'll keep using ISO mode because all these DVDs I'm backing up are DVD-5's so I don't need to edit them.
Sharing DVDs Ripped to HD in File Mode
By pwhelan81 in forum DVD RippingReplies: 4Last Post: 2nd Jan 2012, 09:00 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 08:28 -
How to rename a file when it is in ntfs mode
By mysts in forum ComputerReplies: 3Last Post: 19th Feb 2010, 04:34 -
finding GOP header by opening a file in binary mode
By VBMizio in forum ProgrammingReplies: 1Last Post: 30th Aug 2007, 06:38
