I was wondering if there's a good program that can convert mp4 into avi. Here's the hard part...the mp4 has two audios, russian then english, i want to convert only the english audio to the avi file, what program is able to do this and at the same time retain most of the video's qualities?
EDIT: I now am trying to use Real Media Producer to make these mp4 dual audio files into rmvb...is it possible to choose the sound track then?
Results 1 to 10 of 10
Ok, to lessen any deterioration of he quality I want to also turn it into RMVB, with english audio...any idea how to work this using RM producer?
If it is truly dual audio tracks (not Left and Right different audio languages in 1 track), just use YAMB, as suggested to remove the unwanted track.
It doesn't re-encode; it just repackages the .mp4 (so no quality loss)
Then use the repackaged .mp4 to convert to RM. I have used easy real media producer (free) in the past with success
Not sure why you want to convert it to RM? Why not keep the .mp4? -
Umm...when I installed YAMB the latest version...all I was able to get is some error saying mp4box.exe does not exist or the directory doesn't exist...what's wrong with it?
Just to let you know I really appreciate all your suggestions and help, I'm trying to work them out. I just like small files with only one audio.. -
You downloaded the wrong package. One package contains just the latest Yamb, another contains everything. Either download mp4box separately, or download the installer version of Yamb from here, which mp4box included : http://yamb.unite-video.com/download.html
Read my blog here.
OH I see, also does this do videos in batches?
By the way I heard that .mp4 is core based avi that's not suppose to have dual audio is this true?
Converting .rmvb to .mp4 (Audio not synced w/ video)
By mikeeeeyy in forum Video ConversionReplies: 3Last Post: 15th Jan 2009, 00:44 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 7th Nov 2008, 00:42 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
Help! Converting mkv. to mp4 (dual audio problems)
By ir0n_ma1den in forum Video ConversionReplies: 1Last Post: 5th Jun 2008, 15:50 -
Dual Audio in RMVB files?
By bAz666 in forum Newbie / General discussionsReplies: 8Last Post: 12th Feb 2008, 22:18
