Hi, I was wondering if there was any way toplay VCDs on my computer with certain software or whatever and be able to see menus that i would normally see on my stand alone DVD player. Im not using a DVD drive, just a normal cdrw drive.
And btw, is there ANY way to play VCDs on my playstation 2? I heard you cant!
-iconboy
Hi,
About the PS2 thingie... You can't play actual VCD's on it, but you can convert them to a playable disc fo your PS2.
Check out this post for more info :
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49990&forum=10
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
iconboy,
Most software DVD players can also play VCDs. Good players are PowerDVD and WinDVD. WinDVD will also play SVCDs. For VCD and SVCD it should not be necessary to have a DVD drive.
Also a freeware player called SthsDVD was mentioned in this forum, but I don't have experience with this one. I have seen a download link in this forum, you can use the search to find it. -
there's also powervcd player which is pretty good it plays menus and works like a remote too.
check the tools section on the site for som good player software
F1!! F1!! F1!!!
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 15:28 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 12:37 -
Playing vcds on Liteon lvw 5001
By northy44 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Sep 2007, 07:50 -
I can not run some VCDs on My Computer. Need some Assistance.
By wapw in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jul 2007, 14:45 -
Authored DVD with GFD, fine on TV, no menus when playing on computer.
By towtruck in forum Authoring (DVD)Replies: 6Last Post: 8th Jun 2007, 17:40
