I am using Super and I keep getting a popup window with an error.
My Drive C is small and only has about 15GB free. My drive D is a 500GB drive with over 380GB free.
Every time I run Super I get popup window with an error stating that Drive C has less than 20GB of free space and that I will have problems.
If I try to convert more than one, one hour video at a time, the second one errors out part way through.
Anyone know if I can change the paths in Super so it looks at Drive D where there is lots of room?
Right-click in main window and select 'Output File Saving Management'.
Chose your drive and save the changes. -
Already did that, the output drive is my D data drive.
What the error is is the "working" drive which insists on being C. -
You might like to try un-installing and re-installing the program. I cannot remember now if it gives you a option of where to store the install. Some program will always install in the windows working drive.
VOB2MPG and network paths
By kfealz in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 5th Jan 2010, 20:21 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05 -
SUPER - is it really super? (a behind-the-scenes look)
By BaronJT in forum Video ConversionReplies: 5Last Post: 2nd Aug 2009, 09:29 -
Moving Paths/Keying Help
By Trunkz Jr in forum EditingReplies: 6Last Post: 10th Apr 2008, 19:01 -
audio take different paths in PS2 and computer?
By willmoodom in forum AudioReplies: 4Last Post: 17th Sep 2007, 18:39
