Recently I was stuck with a trojan that Norton or Kaspersky did not see or find but with the help of Spyware Doctor I was able to clean it out.
But here is the interesting problem, with the Spyware Guardian running in the background, the SVCDtoDVD loads fine but freezes up when I go to click Add Assets. Have to force the shutdown and start over.
When I disable Guardian load assets works fine. Once the asset or assets are loaded I can reactivate Guardian, it does not affect the encoding process.
Should be noted that within Spyware Doctor I had identified the svcdtodvd.exe to the allowed list but had no effect.
Just curious if anyone else had come across this.
Randalliser
Don't know about the particulars in your case, but it's been my experience that
resident shield type of protection often has the side-effect of interfering with
just about anything non-trivial you try to do with your PC. Since almost all
the nasties get on your machine through the browser, I've taken the approach
of running the browsers in a sandbox instead of everything on my machine.
One way to do this is with Sandboxie.
Unfortunately with SP1 Sandboxie is no longer supported on a Windows 64 bit OS.
But it still works fine on 32 bit flavors of Windows XP and Vista.
I do the occasional scan for adware and viruses but I just don't leave the
anti-virus running resident. It's much simpler to redirect browser disk
writes to the sandbox folder. Also if you don't like that approach there
are some free anti-virus that you can set up to filter the http input
streams exclusively so the impact on other stuff is minimal.http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
interesting security problem, need some input
By deadrats in forum ComputerReplies: 3Last Post: 23rd Nov 2009, 22:58 -
50 Interesting Facts
By fairytale00 in forum Off topicReplies: 6Last Post: 4th Mar 2009, 21:05 -
Interesting Connection Problem. LG DVD Recorder to Samsung LCD TV
By kramsey999 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Oct 2008, 01:13 -
interesting VEGAS 8 render problem
By compusic in forum EditingReplies: 3Last Post: 8th Mar 2008, 08:11 -
Interesting problem with new Sony titles
By Nilfennasion in forum Newbie / General discussionsReplies: 8Last Post: 25th Aug 2007, 08:01
