G'day,
I've been trying to get some subs to show - been using all the info i can get from these forums but am still having problems. I've got a movie .avi and .srt subtitles Hopefully someone here can help me out!
Here's the situation:
* I've given the .srt file the same name as the movie and it works on the computer but not on the DVD player, so..
* I started out using AviSub but on the resulting .divx file created - nothing appeared - not on the computer nor on the TV.
* I read somewhere that some players "like" .srt while others, the .sub and .idx combo thing so i use Txt2Vobsub to create them and chucked them onto a disk together but still nothing
* I then found sub2divx, used the vertical adjustment to 96 and selected PAL in the top left box (i'm in Australia). The subs appear on the computer but not on the TV. (althought its worth mentioning that the .avi info button in sub2divx says the file is NTSC - should i set it to NTSC to match the file or to match the TV/DVD player which are PAL?) Is there anything that i am doing wrong in this program thats causing the subs not to appear on the TV?
* I've used DVDFlick, which is nice and all, but wants to convert the 700MB .avi i'm working with to a full blown DVD of greater than 2GB. This seems like a rediculous option. Perhaps the file size can be reduced, but i've yet to find that option.
Can anyone suggest anything i could try with these programs to get things going? Or even any alternative programs that would be useful? I've read that you can use AutoGK but that takes 3 hours while these take next to no time, so i'd rather try to find a quicker way.
BTW - i've got a PANASONIC DMR-ES35V VCR DVD combo player that does have the DivX logo & says "plays Divx 5, 4, 3, Divx VOD". I've heard that some players don't "like" divx subs - is this enough info to show that mine can play divx subs?
Phew! Thanks for your time guys!
Turns out it was the subtitle button. Wasn't actually on the remote - had to access a bunch of menus to get it working.
Thanks for your help!
sub2divx and mpc problem
By Docoptik in forum SubtitleReplies: 5Last Post: 31st Jul 2011, 19:58 -
What's wrong with Sub2DivX!
By kehn in forum SubtitleReplies: 4Last Post: 27th Dec 2008, 11:21 -
Problem with Persian subtitle in Sub2Divx
By phn_uk in forum SubtitleReplies: 2Last Post: 25th Apr 2008, 07:10 -
How to use Sub2Divx to create DIVX file with switchable sub
By hmanhha in forum SubtitleReplies: 2Last Post: 18th Mar 2008, 08:55 -
i get creation failed with sub2divx
By shimi in forum SubtitleReplies: 0Last Post: 5th Jul 2007, 15:39
