I downloaded an MP3 from an artist's myspace site and want to put the song on a mix CD. The MP3 sounds good when I play it in iTunes or with Quicktime (I am using a Mac G5). But when I drag it into Toast, it sounds bad. Loud metallic sounding static appears on the track, as if it is protected in some way. What can I do to remove this noise, which I assume is some kind of copy protection? Thanks.
Hi, danielmak.
I understood your problem, but still iam unable to help you, as i don't have sufficient knowlege of that. -
I converted to AIFF in itunes and the version in itunes still sounds good, but when dragged to Toast, still sounds bad. I converted that AIFF to FLAC and dragged the FLAC into Toast, but had the same problem. I burned with iTunes and it worked. Thanks for the tip. I don't usually mess with iTunes beyond adding stuff to my iPod. Take care.Originally Posted by guns1inger
MP3 CANNOT be copy protected. However, you could have 2 issues with the original MP3 file.
1) The original might be of low quality with a low bitrate and the conversion just makes it obvious.
2) The original might be encoded with MP3 Pro which is NOT downwardly compatible with iTunes and probably Toast and it's botching the conversion for audio CD because MP3 Pro requires special software. I have no idea how to deal with MP3 Pro or what you would need to do so, but artists often don't understand technology, so yeah, I could see that somebody might actually think using MP3 Pro is a good idea. Or maybe they used it deliberately to make it hard for you to do anything with it if you downloaded it.
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 17:13 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 05:36 -
Mp3 to Mp3? Audio Compresstion / Down sampling?
By YuJay in forum AudioReplies: 7Last Post: 7th Dec 2008, 13:05 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 26th Aug 2008, 00:59
