I used a HV30 to film a kids performance outdoors. After capturing I noticed lines in the video when zooming and panning. Where does this come from? The tapes maybe? I can upload a sample if someone can tell me where to do it and what size needs to be.
Results 1 to 14 of 14
HV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850
Probably. But unless you're making a video specifically for playback on computers you probably don't want to deinterlace.
Doesn't the HV30 have a 24p mode? A 30p mode? In the future you might consider those if you don't need the greater temporal resolution of 30i. -
Ok so I have been recording in standard DV, what your saying to do is use the hdv 24p or 30p to record in. I'm still new to this cam, about a week or 2. I think I just discovered the 24p and 30p modes are only in HDV and not the DV setting. But in theory if I want DV for my editing I can record in HDV and then set output (for capturing) to DV and then I wont have this problem??
HV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850 -
Keep in mind that interlacing isn't a problem. It's the native state of NTSC video. If your final product is TV then you should leave the video interlaced and the TV will display it correctly.
In the special case of shooting video that you will distribute on the internet (and therefore can't be sure what players people might be using) you want to either shoot progressive video to start with, or deinterlace. Since you camcorder has a 30p option I would use that (24p can be a little tricky). -
Correct me if I am wrong but 30p can only be used in hdv mode?
Yes, but the output from this will be DV in "DV lock" mode.Originally Posted by Jensen
If you are recording things that you might want to watch in the future(!) it is strange to shoot DV on an HDV camcorder - what did you pay all that money for?
Cheers,
David. -
I had no idea what "DV lock" was so I searched and found this:
http://www.hv20.com/showthread.php?t=10949
The HV30 can convert HDV to DV during playback using its DV lock feature. Of course, you could always capture as HDV and downsize to DV too. -
Originally Posted by 2Bdecided
Lol, I never thought of it that way. I guess I figured DV was DV and HDV was HDV. If my outcome was eventually to be DV why not just use that? But I didnt realize that HDV 30p, even with DV lock, would make my DV better. I also figured that after editing HDV, then encoding to mpeg2 or wmv would take allot longer (even though I haven't tried it). Still learning the ropes.HV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850 -
Glad I was sober when looking at that, I can see the difference. Im confused as to which is which. I am assuming 30p on top and 30i on bottom.
It's actually 60p on the top, 30p on the bottom. 60 different frames per second on the top, 30 different frames per second on the bottom. The top is similar to what you would see on a TV, much smoother motion (on an interlaced CRT you would see one field at a time and it would flicker a bit). On the bottom you should see fast-jerky motion.
Exactly what you see may vary depending on you monitor and computer. Both might be jerky if you aren't running the monitor at 60 Hz. They might be blurry on an LCD with slow response time. The frame size is pretty small so most CPUs should be able to keep up. -
When shooting HDV 30p and then down converting to a wmv for internet use, am I gaining anything other than having a HDV copy in my back-up? Is there a certain codec that would benefit more from shooting in 30p? h.264 would be my first guess but takes time and is kind of hefty in size.
HandBrake Video Jitters During Panning Scenes
By ejai in forum DVD RippingReplies: 10Last Post: 14th Feb 2011, 14:50 -
Remote controller and video panning
By caio1985 in forum Authoring (DVD)Replies: 10Last Post: 14th Aug 2010, 22:25 -
QUERY: zooming in/out and panning... of screen video capturing
By andwan0 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jul 2010, 06:21 -
help with VHS tapes with lines int he middle
By curt1sw in forum RestorationReplies: 6Last Post: 14th Dec 2007, 08:51 -
Matching different video clips/Zooming in on audio in Adobe Premiere
By PharmBoy in forum EditingReplies: 3Last Post: 20th May 2007, 16:42
