Is there a way to find the hard drive serial # instead of opening the computer and taking the HD out. Is there a program out there that will show you the serial #. Thanks
Sorry didn't work, it said no serial #. I guess i need to open the PC, thanks for the help.
control panel>system, select the 'hardware' tab>device manager, expand 'disk drives' then right click on the hdd in question. select properties then click the 'details' tab. from the drop down box select 'hardware ids'
This will give you the model#, not the serial#.control panel>system, select the 'hardware' tab>device manager, expand 'disk drives' then right click on the hdd in question. select properties then click the 'details' tab. from the drop down box select 'hardware ids'
To get the serial# (as well as other usefull info) I use a utility called HD Tune: http://www.hdtune.com/download.html
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Serial ATA hard drives on dvd recorders ?
By joecass in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2009, 17:32 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06
