I have some OGM files that I am trying to convert to DVD via CCE. I have 2 Computer that I thought had the same exact software on them.
One Computer is able to load the file in CCE and the other one is not able too.
Here is the avs script I am using:
<SCRIPT>
# -= AviSynth v2.5.7.0 script by FitCD v1.2.8 =-
DirectShowSource("C:\myvideo.ogm")
LanczosResize(720,376,2,0,700,400)
AddBorders(0,48,0,56)
ConvertToYUY2()
</SCRIPT>
One thing that I noticed is that when each computer is loading the file in CCE, they load different things in the Systems Tray. The computer that works loads the icon to the very left in the picture below:
The computer that doesn't work tries to load what looks like a DivX Icon and the standard Haali Splitter Icon.
They are both using CCCP, which I have been using for years, but one seems to work and the other doesn't seem to work.
What software generates the icon in the picture?
if you go into your control panel - add/remove programs list, the icon a program uses is displayed next to it.
i can't identify that one, sorry.--
more likely it's the ogg codec/filter/splitter one computer is missing.
https://www.videohelp.com/tools/OGG_DirectShow_Filter_OggDS_OGM_Codec--
aedipuss, yes that was it. The OGM will at least open in VirtualDubMod now. Unfortunately, it will not load in CCE or VirtualModDub using AviSynth. VirtualModDub throws an error stating that it cannot determine the FPS. I believe there is a function called assumefps or something in Avisynth and I will play around with that when I get a chance.
FWIW, I finally figured out what the issue was. The CPU that would load the OGM file into CCe and VDM always displayed OGDSOGM Codec icon in the systems tray. The CPU that would not work, displayed DivX and OGDSOGM Codec in the systems tray.
That is whan I remembered that I had just installed "AVI2ISO". After uninstalling it, the CPU in question works. Not sure if there is a conflict or what.
Change Icon In System Tray?
By DarrellS in forum ComputerReplies: 7Last Post: 8th Feb 2011, 23:36 -
Haali Media Splitter tray icon gone
By SvenVolfeid in forum Software PlayingReplies: 4Last Post: 7th Feb 2011, 06:46 -
Question how to change icon of software icon
By jimdagys in forum ComputerReplies: 3Last Post: 10th Oct 2009, 04:47 -
Problem with Norcent DVD Player, Tray keeps open/closing, tray disc error
By daveshostack in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Feb 2008, 11:41 -
Question regarding .ogm
By Justin Wade in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 12:39
