Hi!
Well I'm in a fix. I have a DIVX AVI with compressed audio. I decompressed the audio using (avi2vcd) With the Avi decompressed I brought it over to (TMPGEnc) and set it up so it'll open. Everything started to work fine. It was encoding like a mad man. Until the 25-30% mark, then the visual and audio ceased to exist and I was left with nothing.
I decided to burn what I had to see if the vcd would look alright and thankfully that turned out. Albeit only 25% done.
have any thoughts?
Does the divx file play all the way through without error? If your file stops playing and you have to move the position slider to watch the rest, then you are going to have encoding problems.
In Media player it works fine. The entire movie shows up. Why is it that it suddenly cuts out in TMPGEnc?
MPEG-2 528x576 to AVI conversion problem.
By madman1987 in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:53 -
Quick .avi Conversion to MPEG-2 ?
By christopheramos in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 18:42 -
Mpeg-2 conversion with TMPGEnc: output too bright
By Novie in forum Video ConversionReplies: 10Last Post: 23rd Nov 2007, 10:31 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
