Results 1 to 14 of 14
    Sep 2007
    somewhere in videohelp
    hi, what was the codec for realmedia ?
    ( sorry if repost )
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    What do you mean ??
    WHat codec do you use to play realmedia ? or what codec does real media use ??
    Either way... realmedia, it's their own codec, tools > codecs > Real Alternative for a bloat free codec for real media files (which are pretty much crapolla)
    Sep 2007
    i want to render video clip that type realmedia with tmpgenc express
  4. Mod Neophyte redwudz's Avatar
    USA
    Real Alternative will install a codec to read Real Video and your video may then be accepted by TMPGEnc. No guarantees with some forms of RMVB video. If you wanted to encode to the Real Video format, you would have to use something like Real Producer or other Real product, AFAIK. Or maybe RealAnime would work. Real Video is a very proprietary format, so there's not a lot of programs available to work with it.
  5. Member zoobie's Avatar
    Feb 2005
    Florida
    what are you trying to do?
    real media isn't recommended
  6. Member zoobie's Avatar
    Feb 2005
    Florida
    you want to put real media on a DVD?
    you sound very sketchy....
    perhaps sell it?
    Sep 2007
    i know real media isn't recommended that's why
    i want to render real media to mpg
    perhaps sell it?
    and no, i don't selling anything
  8. Mod Neophyte redwudz's Avatar
    USA
    If TMPGEnc fails, there is also ConvertXToDVD that can handle some RM formats. A method I use for RM conversion using AVIsynth is this: https://forum.videohelp.com/topic289872.html
    Sep 2007
    and just found out, i use Super too, to convert to avi
    thanks guys for all your help
  10. Member bendixG15's Avatar
    Aug 2004
    This reads like a bad high school skit. :P
  11. Banned
    Jun 2004
    Converting it to mpg wont help, it's already crapafied in realmedia format
    Well that was real clear from your previous post
    NOT
  12. Mod Neophyte redwudz's Avatar
    USA
    Not all of us are native English speakers. But I agree the question could have been worded better.
    pcb, I hope SUPER works for you. It's output is often not very good quality and it really doesn't have enough adjustments to improve the quality. But RMVB is also often not good quality.
  13. Banned
    Jun 2004
    I know that
    and i've seen people here go off on people way worse than i ever have or did for writing the same vague way AND for typing like they don't speak english 8)
    But he could have said what he stated the 3rd time the 1st time
    As far as i could tell he wanted to convert something to realmedia, and that after the 2nd post.....
    Sep 2007
    redwudz thanks for advice for Real Alternative, it work for tmpgenc express
    Noahtuck, sorry for my bad english, next time i'll try for better in explanation ( i am not so good in english )
