I started to work with HDV using Canon XH A1. I have however a lot of DV footage which I would like to use. When I import my DV format avi files into the Premier and try to combine with HDV files in HDV setting project the quality of DV drops strongly. How I could use DV file with HDV formats?
By editing the DV footage so you know what you are going to use, then using something like RedGiant's Instant HD or VideoEnhancer to scale the Dv to HD resolutions with minimal degradation. These super resolution programs are slow to process, but can produce better results than a standard resize function when going to HD resolutions. For lower resolution material the value is arguably more questionable.
Read my blog here.
Date/Time Stamp for HDV Footage
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 18th Mar 2019, 02:25 -
Have Canon HDV A1 footage to convert to SD
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 5Last Post: 1st Jul 2010, 12:13 -
Producing DVDs from HDV footage
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2009, 17:25 -
HDV project final export
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 15th Oct 2008, 04:02 -
Aspect HD for HDV project
By kippard in forum EditingReplies: 7Last Post: 26th Mar 2008, 18:42
