    Jun 2008
    Puerto Rico
    This DVD has been great! I am able to play movies from all regions. However, I lost the remote control and I have been unable to find the model to buy it again.
    Does anyone know what's the model of the remote control for Daewoo's DVD S150????
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Your only option is likely to contact the manufacturer. Have you considered an "all-in-one" remote? The Logitech Harmony remotes work very well.
    Google is your Friend
  3. You can get a One For All 8910 for a lot less than a Logitech. I've yet to find anything that can't be operated by the upgradable One For All remotes. If the remote doesn't work out of the box, it can be upgraded over the phone.
