Hello!
I encoded a mkv file (video x264, audio ac3) with a higher bitrate to a mkv file (video x264, audio aac) with a lower bitrate. This process results in an out of sync audio. The delay is variable: at the beginning of the file, the sound is in sync and then it becomes gradually faster than the video.
Here are the details:
The original file has the following specifications
I used MkvExtract to extract the AC3 file and MeGui to encode sound and audio (If I wouldn't encode the audio and use the original AC3 file, I would have the same desync issue):Code:Format : Matroska File size : 12.3 GiB Duration : 3h 3mn Overal bit rate : 9597 Kbps Encoded date : UTC 2007-08-19 00:03:37 Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 Codec ID : V_MPEG4/ISO/AVC Duration : 3h 3mn Bit rate : 8758 Kbps Nominal bit rate : 9132 Kbps Width : 1920 pixels Height : 816 pixels Display aspect ratio : 2.35 Frame rate : 23.976 fps Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.243 Writing library : x264 - core 56 svn-667C Encoding settings : cabac=1 / ref=5 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=9132 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 Language : English Audio Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 3h 3mn Bit rate mode : CBR Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Rear: L R, LFE Sampling rate : 48.0 KHz Language : English
I usually don't have these desync issues with any mkv files. I would be extremely grateful if you could help me in fixing this problem.Code:Format : Matroska File size : 2.80 GiB Duration : 3h 3mn Overal bit rate : 2184 Kbps Encoded date : UTC 2008-05-31 07:19:41 Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 10 Codec ID : V_MPEG4/ISO/AVC Duration : 3h 3mn Nominal bit rate : 1914 Kbps Width : 1280 pixels Height : 544 pixels Display aspect ratio : 2.35 Frame rate : 23.976 fps Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.115 Writing library : x264 - core 59 r851M e11ef38 Encoding settings : cabac=1 / ref=10 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=6 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=0 / mbaff=0 / fgo=0 / bframes=5 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1914 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00 Language : English Audio Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : A_AAC Duration : 3h 3mn Channel(s) : 6 channels Channel positions : Front: L C R, Rear: L R, LFE Sampling rate : 48.0 KHz Resolution : 16 bits
In your avs script, try using convertfps, which usually gets around the vfr problem
DirectShowSource("Path\file.mkv,fps=23.976,convert fps=true)
The other approach would be to shrink/expand the audio in the mkv container using mkvmergegui. The information you provided suggests that both audio tracks and both video tracks are the same duration; so this probably won't work. But anyways: under the format specific options tab (once you highlighted the audio track), you will see "stretch by". Just enter a ratio like 999/1000 to make the audio smaller...etc...
Audio out of sync problem with FFMPEG encoding MP4 (h.264,AAC)
By jenak1980 in forum Video ConversionReplies: 7Last Post: 5th May 2010, 01:03 -
Off sync audio problems - is it ripping or encoding?
By kirklt in forum DVD RippingReplies: 3Last Post: 14th Jul 2009, 10:48 -
Audio out of sync half way through encoding
By gertielongbum in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2009, 13:59 -
Higher bitrate encoding causes audio sync issues
By keiron in forum Video ConversionReplies: 3Last Post: 12th Jun 2008, 04:37 -
I am Legend Encoding (Blu-ray) audio sync issues
By Ansuer in forum Blu-ray RippingReplies: 21Last Post: 1st May 2008, 17:54
