For years I have been converting my avi files to DVD files (BUP, IFO and VOB files) because my standalone player only played DVD files. Now, I just bought a new player that will play DIVX, so how can I burn a compilation of say 10 avi files onto a DVD to watch on my standalone without any conversion?
By the way, I did check the forums and couldn't find any reliable posts, so that's why I'm posting!! Thanks!![]()
Results 1 to 11 of 11
LJB, you are a GENIUS!!!!!!!!! worked like a charm!! I actually thought I had imgburn because I have Decrypter and I thought it was bundled with it. Anyhow I burned them, but I was thinking something... is it possible to add chapters of sorts such as with a dvd file, because I have like 15 avis back to back and I am guessing they will play without stopping and no way to jump forward or backward to a specific avi unless I use the rewind feature, and that could take days!! If you know of a way to do this with the avi files on the DVD that would be great. We could save a lot of money and time in burning avis with chapter separations instead of converting and wasting 1 DVD for maybe a couple movies or such. Any ideas would be great!! Thanks.Originally Posted by LJB
You can add chapters and menus, however
1. They must be authored using a divx authoring tool
2. They must be in the .divx container
3. The menus and chapters can only be seen/used on specialist software players and Divx Ultra certified players.
If you are like the rest of us, you will just have to live with it.Read my blog here.
I don't know which player you have but on mine, to pick a specific AVI I use the player's menu feature and scroll to the AVI that I want and select it.Originally Posted by -mm-
To skip to the next one, I just use the skip button on the remote. -
I actually didn't take the time to check after I had burned the DVD to see if the menu option worked, because the disc started playing right away when I popped it in with no menu, so I figured it didn't have that option. To my surprise, it's as you described.Originally Posted by somebodeez
Thanks both of you for the fantastic help!! Cheers! -
The standalone DVD Player plays my AVI videos, but doesn't show subtitles in SRT format!
I tried SubEdit238 and converted SRT to SUB/IDX format but without any success.
How can I view accompanying subtitles? Please be descriptive (non-technical) in your suggestion.
Sorry and thanks.Last edited by ConverterCrazy; 23rd Jun 2012 at 08:00. Reason: Forgot to add what I have tried at my end
Hi ConverterCrazy,
1) Your AVI and SRT names must be IDENTICAL. For example Drangon.avi & Dragon.srt. Any deviation and your are out of luck!
2) Put your AVI and SRT files into one folder. Create a Folder called DRAGON and put your AVI & SRT in there.
3) Now try viewing your movie Dragon.avi on your dvd player ... it should be there.
BTW, what is your dvd player Model & Brand?
Post back your result for the next person!
Thanks,
G!
Thanks gonwk.
The DVD player make is Videocon -- 5 years old but fully functional. Will post feedback ASAP. -
The subs may not play automatically. You might have to turn them on using the subtitle button on the remote control.
Thanks, manano. I'll try your suggestion as well. Pl see my reply below.
@gonwk
Thanks once again.
The file names were not Identical! But, making them identical didn't work in my case. I had to insert spaces in the file name which I had removed earlier.
Earlier, the file names read like singertitlegenre.AVI and singertitlegenreEng.SRT from singer_title_genre.AVI and singer_title_genre_Eng.SRT.
It is a 4 minute song in some foreign language. I had the English translation of the lyric and I made subtitles from the text after spending a lot of time in fixing timings.
Last edited by ConverterCrazy; 23rd Jun 2012 at 16:40. Reason: Text appeared without paragraphs
MKV to AVI to play in standalone DVD player
By AzzKickr in forum Video ConversionReplies: 8Last Post: 9th Sep 2011, 14:53 -
Which DVD should I use to burn avi files to play on standalone?
By Stealth3si in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2009, 11:22 -
AVI wont play on standalone player, need to convert to what
By haubmi in forum Video ConversionReplies: 13Last Post: 10th Mar 2009, 14:58 -
Why can I not burn DVDs that play in my standalone DVD player?
By bmoreravyns in forum Authoring (DVD)Replies: 12Last Post: 18th Sep 2008, 15:05 -
how to burn and play the MTS files on standalone blu ray player using BD R
By ticos2000 in forum Authoring (DVD)Replies: 12Last Post: 28th Jan 2008, 20:06
