I need to show several simultaneous time-synced video and data streams together on the same screen. I have video and then at least three, possibly more data plots that will be animated and put into the appropriate format: 1) video of events, 2) weather data, 3) several other data streams. The weather and data streams can be converted to an animated movie of some sort I am sure, but I need to synchronize all these various screens.
I have no idea where to start, even what kind of commercial operation to contact on how to do such a thing, or what software package(s)/hardware solutions potentially exist. My lingo might be wrong as well.
Thanks for any and all suggestions.
Results 1 to 11 of 11
You can do this directly in a resonable video editor using overlays and moving paths.
The technique is called picture-in-picture. -
Thanks for the reply. Any recommendation for a reasonable editor with this capability that doesn't have too steep of a learning curve? And that doesn't require a second mortgage to obtain?
Thanks -
Ulead Media Studio. I use version 7 so it's not the latest one but I do find it easy that version 8.
And because it's an older one you may find a copy a lot cheaper. -
So this isn't reacting to multiple live data streams ?
Then editing existing tapes with multiple overlays is easy to do.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I'd also second Ulead MediaStudio Pro. It's what I always use and I shoot the same scene from different angles simultaneously and then cut from one to the other. When deciding which shot to use I apply a Picture in Picture moving path to each one so I can watch them all at once.
This does assume you are talking about recorded video streams though and not live as Ed has picked up on. -
Thanks for the responses.
Yes, the video is recorded, not live, so it sounds like MediaStudioPro is the crowd's choice. I'll check it out.
Thanks -
Ulead video studio is best option. even you can put 6 videos as overlay track and it has much more options like pan zoom scroll etc.
BTW you can download trial version and try for 30 days
Ulead Videostudio is the hobbyists version, MediaStudio Pro is, as the name (and price) suggests, the fully featured version. It doesn't have any wizards or hand holding but is capable of far more than Videostudio ever will be. Up to 99 overlay tracks rather than just 6 for example (not that I can think of any time when this would be needed but just one difference). However, there is a 30 day free trial of both available from www.ulead.com.
Issue with thumbnail creation for videos
By dchilkur in forum ffmpegX general discussionReplies: 1Last Post: 10th Mar 2012, 03:18 -
Batch hard encode multiple language srt to multiple videos
By clonius in forum SubtitleReplies: 4Last Post: 15th Jul 2010, 15:06 -
Multiple Simultaneous Video Capture - is it possible?
By PortoLad19 in forum Capturing and VCRReplies: 6Last Post: 31st Jan 2010, 09:10 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 05:08 -
Single video with multiple simultaneous audio playback
By vhdmi in forum EditingReplies: 0Last Post: 27th Dec 2007, 16:50
