what happen to my dvd format when i play with my car dvd player same of the output show as below
http://www.badongo.com/pic/3686693
http://www.badongo.com/pic/3686750
but same i play it show normal pls help
It could be a PAL/NTSC-issue. Is it a commercial dvd or have you made/converted it yourself?
What if you play a store bought DVD? That means commercial made DVD.Originally Posted by zhanzz2
Idea is to separate hardware or standards format from the problem.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
same commercial DVD i bought is ok but same cannot
or maybe my car dvd player setting is not correct? -
As noted above, it is still likely a PAL/NTSC issue. First, you need to find out the region/format information of your car player. Second, you need to ensure you are trying to play DVD's for the region that your car player supports.
Google is your Friend
S-Video to RCA with black and white output
By faoltaem in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2012, 04:50 -
DVD Palyer - black and white picture
By majstrydwa in forum DVD & Blu-ray PlayersReplies: 10Last Post: 5th Oct 2010, 11:01 -
Black and White TV Output From Nvidia Geforce 8600 GTS
By nicolasqueen in forum Media Center PC / MediaCentersReplies: 7Last Post: 24th Jan 2010, 18:40 -
What are the best settings for black and white DVD to H264?
By Emanef in forum DVD RippingReplies: 9Last Post: 9th Nov 2008, 10:35 -
Can someone educate me why DVD-r are playing black & white
By ericnord in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Oct 2007, 07:34
