I regioned my DVD player using the following instructions and instead of using region 0 which I've always used, I went with region 9 like it said to and now my American DVDs are only playing in black and white. I can't figure out what code I would use to region it again because the code for region 9 isn't listed. Can anyone help?
Region code hack posted by Tiger1, May 24 2007:
Hi I live in Australia and added this model.
acknowledging: Region code hack posted by ZoidsGodzilla, November 22 2006: for the Samsung DVD-V5600
1. Press the DVD button on your remote (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the usa ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 129334
Have Fun :0)
Changing the region would not produce black and white video. Also, there is no region 9. Official regions are 1 - 6. Region 7 is used for Screener players, and Region 8 is for airlines etc. Region 0 usually means either no region is set, or all regions are set. Whatever button 9 does, it doesn't set the region to 9. The instructions imply it sets the player to no region at all.
Things that might cause black and white playback include a change to colour format (PAL vs NTSC), or even a loose or faulty s-video cable.Read my blog here.
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 10:34 -
want to Multi region my Samsung dvd V6700
By nicean93 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Mar 2010, 18:30 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42 -
Samsung DVD-V6700 (US) make them multi region ?
By suAve in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Sep 2007, 08:48 -
samsung dvd-v6700 ayuda urgente
By mairel in forum DVD & Blu-ray PlayersReplies: 9Last Post: 31st Aug 2007, 12:23
