    May 2008
    Israel
    Hi,
    I've captured about 1 Hour of video using my USB capture device...
    I've decided to go with "Standard Play" capturing, and the video look good.
    The video that I got IS Mpg file (MPEG 2 file), so why do I have to go to something like TMPGEnc and encode it for around 10Hours???
    Gil.
    Gil Amran
    Apr 2004
    Miskatonic U
    What are you trying to do with it ?
    If you are trying to create a DVD, is your mpg file compliant ?
    Open the mpeg file in the latest g-spot, and compare the specifications to those in What is DVD - top left corner. if you video is not compliant then you have to re-encode. If it is compliant, you are using the wrong software to author, or using it incorrectly.
    Read my blog here.
