    May 2008
    Portugal
    Hello,
    I have a DVD with a movie a english subtitles. I converted it to DivX.
    How can I add other languages subtitles? And where can I get the subtitles files?
    Thanks,
    Miguel
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Your conversion software should have been able to also convert any other available codecs that were on the DVD. If not, try AutoGK.
    Google is your Friend
    USA
    If you need subtitles, do a internet search. There are quite a few sites for subs available for popular movies. If your subs are .srt format, just add the new ones to the same folder as the old ones. Your player should give you a choice of which one to display. Pay attention to the running time of the subs. Some videos may be a different running times than the subs that are available. You can scan through the video after you add the subs and see if they are in sync.
    And since this is a subtitle question, moving you to our Subtitle Forum. You can check the stickies at the top of the forum for more sub information.
