Hey there,
Bit of a strange question, since I want to convert from a "HR HDTV AC3" avi files to the lower resolution format. Why? Becuase I have a DVD player that play's avi files but it states it has "No Codec" for the following file:
D:\Battlestar Galactica Season 2 HRHD\Battlestar.Galactica.S2E11.INTERNAL.HR.HDTV.A C3.2.0.XviD-SSTS.avi
File : 700 MB (700 MB), duration: 0:42:22, type: AVI, 1 audio stream(s), quality: 84 %, MEncoder dev-CVS-050928-16:38-3.4.2, ,
Video : 583 MB, 1926 Kbps, 23.976 fps, 960*544 (16:9), XVID = XVID Mpeg-4, Supported
Audio : 116 MB, 384 Kbps, 48000 Hz, 2 channels, 0x2000 = AC3, CBR, , Supported
However it will play the smaller, more standard avi files, eg:
D:\nedivx-vapo.avi
File : 699 MB (699 MB), duration: 1:30:04, type: AVI, 1 audio stream(s), quality: 51 %, VirtualDubMod 1.5.10.2 (build 2540/release), ,
Video : 614 MB, 953 Kbps, 23.976 fps, 624*256 (2.43:1), XVID = XVID Mpeg-4, Supported
Audio : 85 MB, 132 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, CBR, , Supported
Normally I would just ask, "Can you convert from MPEG 4 to MPEG3" or something similar, but I am a bit confounded here, since both video streams say MPEG4, and only the audio stream seems different, however I am still of the opinion the HR video component is the culprit for the video not playing on my player...
Note: my DVD player is a component player, and does not have upgradeable codec's, as far as I am aware..
Any thoughts?
Holy conversion Batman!
I just discovered CovertXtoDVD!
Converting those HD avi's to DVD format as we speak!
Nice! -
Both videos use Xvid (MPEG4) for the video. Audio is MP3 in one, AC3 in the other. Your player probably supports both audio types. You need to resize the video frame down to a size you player can handle. Try 640x368 or 704x400. Use a program like VirtualDub or AviDemux.
Wrong Codec ??? (for DTS to AC3 conversion) Please help!
By KushSmoka420 in forum AudioReplies: 4Last Post: 29th Dec 2011, 07:50 -
RESOLVED - Video sometimes dark - loading different / wrong codec?
By gepetto in forum Software PlayingReplies: 5Last Post: 7th Mar 2011, 14:23 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Wrong audio codec tag/label!!
By Ijaja in forum AudioReplies: 2Last Post: 28th Sep 2010, 02:32 -
Did I install the wrong mp3 codec?
By Havoc X in forum Software PlayingReplies: 3Last Post: 2nd Jun 2008, 21:22
