HI!
Which software can i use to cut & joint movie files in rmvb(21 chapters) format?THANKS SO MUCH in advance![]()
$200 for their editor
best to convert to something else and edit
that way it's free -
RMVB would likely be one of the worst formats ever created to edit in.
It was made as an 'end' format, not for editing. It's also a highly proprietary format with very few programs offered to work with it. And the variable bitrate makes it twice as hard. I would go with the recommendation to convert it to another format or don't bother trying to edit it.
You should be able to work with some RMVBs the VirtualDub (Mod) by using Avisynth to open the file in VD. Then convert to it to a AVI type format, edit, then encode to a more usable format. https://forum.videohelp.com/viewtopic.php?t=289872
Just one suggestion.
Software TV Studios use to edit/cut splice logos & commercials etc....
By Moontrash in forum EditingReplies: 11Last Post: 14th Oct 2010, 22:52 -
Best Software to Edit VOR & IFO Files from Panasonic RAM Disk & Arc
By JDex in forum Newbie / General discussionsReplies: 16Last Post: 30th Sep 2009, 05:55 -
rmeditor unsupported codec, how to cut rmvb ?
By kclgad in forum EditingReplies: 3Last Post: 7th Apr 2009, 06:38 -
Extract audio and edit from RMVB
By sychern in forum Video ConversionReplies: 1Last Post: 16th Oct 2008, 03:45 -
RMVB free edit tool?
By DereX888 in forum Newbie / General discussionsReplies: 10Last Post: 19th Aug 2007, 13:24
