Results 1 to 13 of 13
  1. I am trying to load this audio file into goldwave which is a MPEG-1 Layer 3 audio file and i get this error what do i have to do please
    Oct 2005
    666th portal
    you might need to install a mp3 codec. look for lame in the tools section on the left.
  3. I have installed lame on my system but still get same error I also have L3CODECA.ACM in system32 folder what am i doing wrong 8) this is a snapshot below of the audio file i extracted from movie to increase sound
    Apr 2004
    Miskatonic U
    Did you actually install it it by right-clicking on the inf file and selecting Install ?
    Read my blog here.
  5. Originally Posted by guns1inger
    yes i did here is the movie which i want to edit the audio
    and this is how i installed lame
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I believe you have to right click and install the dll file, not the txt file highlighted above. You may also need to uninstall/reinstall Goldwave after getting Lame properly installed, but I don't remember having to do that.
    Google is your Friend
    Jun 2008
    try changing the file extension to .mp3
    Nov 2002
    Try using the lameACM.zip file instead of the rar file.
    I set XP up to act like Windows 98 and Windows 2000 because XP sucks. You'll need to use an unzip program like Winzip because XP's unzip program sucks also.
    Here is how my lame folder looks using lameACM.zip.
  9. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    From the icons in the OPs post, it looks like he is using WinRAR, NOT the built-in XP app. And in my experience, whichever compression app you use will typically work or not. I've never had one unzip and the files in some unusable way. Typically, you will open a known good file and it will appear empty...at least in my experience.
    By the way, I like your install graphic.
  10. Knows a few things Stiiv's Avatar
    Aug 2004
    Fallentown, PA
    Here's an idea.....ask on the Goldwave forums! Yeah yeah....duh.
    Stiiv
  11. Banned
    Jun 2007
    UNREACHABLE
    Use AVI-Mux GUI or something for removing the WAV header from the mp3 file.
    Nov 2002
    Just open the AVI in Goldwave. No need to extract a wave file (or mp3 file). If you have the Lame codec installed as GSpot states then Goldwave should open the audio in the AVI.
    If all you need to do is increase the volume then open the file in Virtualdub and under Audio > choose Full Processing Mode and choose Volume > put a checkmark in the "Adjust volume of audio channels" box, raise the slider and click OK (test the volume with the output arrow). Under Audio Compression > choose the Lame codec and pick 128kbps CBR. Under Video > choose Direct stream copy and save new AVI.
