    May 2008
    I have Sanyo "XACTI" HD 1000 movie cam. It records FULL HD in MPEG4 AVC H.264 format. When i import the Full HD video clip in Mac, all i see is a green screen. Can't see the video clip. Why? anybody has a solution???
    thanks
    raju
    india
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    What are you using to play the video? If you're using Quicktime, you might also want to try playing it using something that doesn't depend on Quicktime, such as VLC or mplayer, to be sure it's not just an issue with the Quicktime components you have installed.
    Add the Perian plugin (just to see if that resolves things).
