IsoBuster
I'm trying to open a DVD and ripp contents to desktop using IsoBuster
but it coming up blank disc, it's not recognizing disc contents
I've even tried the my computer way
The contents is there on disc even though it states not.
It ripped and finalized ok.
What other software can i try?
If this doesn't work, https://forum.videohelp.com/topic350554.html#1848070 then something is downright wrong with the disc. I have been luck thus far, and have been able to retrieve "lost" video DVD's from my standalone recorder. Apparently, some people aren't able to do this with the free functionality of IsoBuster, depending on what recorder they used.
-The Mang -
Hi.
Someone had recorded a documentary for me
The disc used was that crap media with the clapper board design on it.
What about using another drive? -
Not very helpful for your problem, but try looking at another ISO reader software
I used ISOBuster for a very long time, but it had issues sometimes so I used to use two different software packages, with ISOBuster being the main one and the other when ISOBuster couldn't handle it
I now use UltraISO Premium, after trying MagicISO as well and haven't used ISOBuster since, ULtraISO Premium reads everything that ISOBuster can and images that ISOBuster struggled to read correctly
Plus, if you look via Google you might find a 'portable' version of UltraISO Premium. This means that it will happily run from a USB pendrive or you don't need to install it. It will run from anywhere you create the folder
I use portable software on my USB pendrive I carry to help sort our peoples computer problems. No need to install anything on a damaged system, it all runs off the pendrive
isobuster
By BaPW in forum EditingReplies: 2Last Post: 11th Feb 2012, 03:05 -
ISOBuster help
By mcf57 in forum DVD RippingReplies: 10Last Post: 5th Aug 2011, 08:23 -
Merging the contents of 2 DVD into 1
By txl in forum Authoring (DVD)Replies: 4Last Post: 7th Oct 2008, 08:24 -
How to send contents of disc by email???
By sarainelkins in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2008, 16:51 -
\EXTRAS contents must be capitalized too?
By spamiaint in forum Authoring (DVD)Replies: 5Last Post: 7th Aug 2008, 08:57
