Probably a stupid question but I've never used printable discs.
Is there any problem using verbatim ink jet printable discs in a non-printable burner?
I've got LG 855 & Pioneer 115d burners.
As far as I know, burners that "print" use lightscribe discs not inkjet printables, and yes you can use them to burn as I am guessing that the data side is identicle?
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
There's no such thing as a "printable burner". Ink jet printable discs are printed on printers. The printing of a label and the burning of data are unrelated. victoriabears is right that there is no difference in the data side between ink jet printable discs and what I guess we could call "normal" (non-printable) discs, so burn away without fear. You can print nothing on the label, write on it with a Sharpie (or similar pen) or try to borrow a printer and put a label on it later.
Thanks for clearing that up.
I'll give the verbatims a try. Might as well as I find myself making marks with a sharpie on non-print discs tho I keep it to a minimum.
What printers print on Blu-ray inkjet printable media?
By videobread in forum MediaReplies: 4Last Post: 23rd Dec 2010, 19:08 -
whats the best printable discs to use for a govideo dvd vcr combo
By zerocoool in forum MediaReplies: 1Last Post: 8th Mar 2010, 00:13 -
Printable discs VS Lightscribe
By omega_weapon in forum MediaReplies: 15Last Post: 24th Apr 2008, 14:05 -
Quality of DL Printable Discs in Australia
By curlyween in forum MediaReplies: 4Last Post: 28th Nov 2007, 20:45 -
Highest Quality DVD+R DL Printable discs?
By Cyrax9 in forum MediaReplies: 3Last Post: 17th Jun 2007, 23:15
