Hope this is not a stupid question.
VLC media player has a aspect ratio and crop setting of 16:10, if you wanted to encode a video to avi, how do you get an aspect ratio of 16:10 from a 4:3 video source?
Thanks,
4:3 is equivalent to 16:12, so to achieve 16:10 you would need to crop off ~3% off top and bottom, or ~6% off one of them.
Assuming you have a 720x480 resolution starting point, cropping 15 pixels off the top and bottom, or 30 pixels on one would do the trick.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
What about a 640x480 resolution, does the same apply? Also would encoding at 640X400 do the same thing? I'm
trying to get a 16:10 aspect without stretching.
Thanks, -
"without stretching" meansOriginally Posted by SWBisbee
Letterbox for wide 16:9 720x480.
Side bars for 4:3 720x480.
Explain why you want to encode for 16:10? Why encode your video to a non-standard aspect ratio?
VLC can play 16:9 to 16:10. I forget if it stretches vertically or chops off the excess sides.
4:3 will always have side pillars on a 16:10 screen unless you zoom to chop top/bottom.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yeah, I don't see the point either. And it's more than 6% you'll lose. For example, starting with a 640x480 AVI, making it fill a 16:10 screen means making it 640x400, cropping 40 pixels from both the top and bottom, making it 83% the original height. You'll loose heads and legs.
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 17:31 -
Aspect Ratio
By ping182nz7 in forum EditingReplies: 12Last Post: 26th Apr 2010, 13:30 -
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 17:40 -
what is aspect ratio?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 3Last Post: 29th Sep 2007, 22:29 -
keep aspect ratio?
By Dunkan21 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 13:27
