Hi mymonaro ... How are you ?... God Bless you..
till now useles to make STB able to view videos with trp - converted -...
no preblem I am waiting & searching better STB , or newly developed..., I am reading and asking about : dreambox-800HD-PVR , & Q-box , Azbox , Captiveworks-CW4000HD , and others , and discussed with some friends in some forums...
now I bring a simple STB .. it is : Starcom1000hd ( all STB-s I tested was not buying it but I have a relation with Merchant importing STB and every a few days I take a new one comes in the market and I study a check it to now all features and how its features good or bad ...,
now I am asking for a converter from FLV to : ( TS ) which is the best that does not increase the size of video file to exaggerated size I mean not 3 or 4 times than origin size.. this make the hard full with less records...and STB Unable to load the full hard especially simple STB , ( except best quality such as dream box & etc..) , Now I am using : ( Total Video Converter ) ...
so if you have one please give me the link for that ...
Thankyou ...
Regards...
Results 31 to 41 of 41
Hello Sam,
I am fine thanks. How are you?
I know of two programs which will convert to TS file format, but I can not make a comment about the file size and I have not run a test of converting flv to TS. Let me know when you try the programs out.
To convert to ts file format the QuickMedia Converter program will do the job (the same program which I refer to in earlier posts in this thread: http://www.cocoonsoftware.com/
Another program is: http://www.easy-video-converter.com/
I have been using this program recently to edit videos (removing short segments from the original video). I like this program, but it could be improved by some extra editing features/options.
Both programs are freeware. Whereas, Total Video Converter is not freeware, I tend to recall this when I was searching extensively a few weeks ago for video conversion programs.
Good luck, let me know how things work out.
mymonaro -
Hi all
Just got a DGTEC DG-HD0211 set top box from DSE for $99 & has a USB slot etc
Well the same old story the FORMAT is in TRP
my set top box has - .trp .idx .ifo FILES when i record off tv BUT the .trp & .idx are in the FOLDER & .ifo is in the MAIN ROOT
also the FOLDER has the ICON ~ at the start of the file name eg: ~METALLICA ONE
So I followed the Instructions & put the files in the right places & added ~ at the start of the folder name
when I scroll over the FILES I recorded off the TV its shows MB's etc BUT when I scroll over the FILE I create it has no MB ZERO
then tries to LOAD but freezes & wont play
does anyone else have this problem ??????
cheers
p.s. also if I leave the ICON ~ out its says file to short in length to play (gotta be longer then 60 sec) so I have almost got it going might be something simple -
As I do not have the same stb as you, sorry but I can not comment about the brand of box.
However, I am curious, I am not clear where your problem is; are you wanting to play the stb recorded program on your computer, or wanting to play a computer generated file/s on your stb? -
my PC video files to TRP so I can play on my STB threw a HDD or USB 2.0 drive
I might just take my DG-HD0211 back to DSE & get one what plays Divx mpeg files, the DGTEC 6760 can playback Divx 6 & mpeg 2 on the USB but I dont know about recording to a USB or HDD lol
thanks your instructions where great but my STB keeps freezing & wont play the file or if I dont add ~ it says file to small to play
Okay, thanks for the update.
Just out of interest, were you converting your computer files to "trp format" using the instructions which I had posted in earlier posts? -
YES
But to get it to play/freeze U gotta put ~ in the folders name EG: ~Metallica One
or if it like this EG: Metallica One says file not long enough to play
my USB look like this when i record something:
TimeShift (folder empty)
RESCUE SPECIAL OPS -RPT.ifo
~RESCUE SPECIAL OPS -RPT (folder)
RESCUE SPECIAL OPS -RPT00.trp
RESCUE SPECIAL OPS -RPT.idx
.trp & .idx are in the folder -
http://www.strong-technologies.com/frmProdDetails.aspx?id=311
I might buy this for $129 & it does play Divx & records
ClarkeTech Movie Converter v1.01 just converted *. TRP and *. IFO but why IDX File, File IDF, RAP File and file type Microsoft Office Access Add-in is not created, while the movie plays in the STB to require all such extensions
Need help - Convert .trp to PC recognizable format (Missing Header Sequenc)
By geek7899 in forum Video ConversionReplies: 16Last Post: 8th Apr 2012, 18:49 -
Best file type to convert .trp for Final Cut editing
By kmxe in forum Video ConversionReplies: 2Last Post: 25th Oct 2010, 13:26 -
Help !!Convert a trp file with Mpeg streamclip
By caliman in forum Video ConversionReplies: 0Last Post: 21st Oct 2010, 12:55 -
How to convert avi to trp so I can play it in my viewsonic 360 reciever
By krykson in forum Newbie / General discussionsReplies: 1Last Post: 17th Oct 2009, 17:40 -
How to convert .trp files?
By ecptavares in forum Newbie / General discussionsReplies: 2Last Post: 28th May 2009, 09:47
