Hello,i dv that is in the editing stage i working with vegas 5 i planing to split the sceen in four with diferents parts of the main video runing and then after a couple of secons return to a normal wiew
if that possible to do with vegas 5, if not how is made and what is need to archive that also if that have a tech name how is called
I will apreciate any help
Thank you
Yes, you can do it with version 5. Look up Track Motion in the help files. You will have to use a combination of track motion and keyframes to control the video frames zooming in and out, but it is very simple once you get the hang of it.
Start by putting the four videos on the timeline, and use Track Motion on each timeline to position and resize the clips in to the four quarter areas. Then you can use keyframes on each timeline to resize the videos over time to give the zoom-in/zoom-out effect.Read my blog here.
recording from a cam in front of stage
By smartel in forum AudioReplies: 5Last Post: 7th Jul 2011, 08:45 -
At What Stage Do I Convert NTSC DV to Burn PAL DVD?
By Dubinvero in forum Video ConversionReplies: 4Last Post: 5th Oct 2010, 18:03 -
XP chkdsk stops at 56% on stage 4 of 5...
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 17th Jul 2009, 00:11 -
Electrical Requirments for Church Sound Stage Setup
By GT Music in forum AudioReplies: 4Last Post: 6th Feb 2009, 14:45 -
Capturing AC3 - Stage Two
By Nelson37 in forum AudioReplies: 2Last Post: 11th Nov 2007, 09:01
