Hi,
During the last year till now I used DVD Rebuilder pro with CCE-SP2 Trial version 2.70 Ver 1.00.00.11, but now I changed my hardware PC (new motherboard and Q6600 processor) and I installed everything again.
I don't know if i forgot how to install it, but I got this error when I want to encode the dvd: Is not a ECL for CCE SP Trial Version.
This is my Rebuilder.ini
[Options]
CCETargetSectors=2260000
CCEAQM=1
Mode=1
OneClick=0
ReduceOpt=0
NoWarn=1
AdditionalOutput=1
LogFile=1
QuEncHQ=1
EncoderMinimized=1
RemoveDTS=1
HC_Quality=1
HC_Matrix=1
SkinVersion=12
AudioDub=1
QuEncodeType=0
iDCT=0
GOP=0
DCPrec=0
MainMatrix=Encoder Default
LowMatrix=Same as Main Feature
VLowMatrix=Same as Main Feature
ExtraMatrix=Same as Main Feature
ProCoder_Quality=4
DVD_Label=FILM
DVD_Name=FILM.ISO
MovieOnly=0
HalfD1=00
Convert_16_9=00
DisableInterlace=00
ConvertToYUY2=1
CCE=3
Skin=Rebuilder Default
HighMatrix=Same as Main Feature
MedHighMatrix=Same as Main Feature
MedMatrix=Same as Main Feature
[Paths]
QuEnc=H:\Archivos de programa\DVD-RB PRO\Encoders\QuEnc\QuEnc.exe
ReJig=H:\Archivos de programa\DVD-RB PRO\Encoders\ReJig\ReJig.exe
HC=H:\Archivos de programa\DVD-RB PRO\Encoders\HC Encoder\HCbatch.EXE
FFMPEG=H:\Archivos de programa\DVD-RB PRO\Encoders\FFMpeg\ffmpeg.exe
CMDLINE=H:\Archivos de programa\DVD-RB PRO\Encoders\CMDLINE\mencoder.bat
ProCoder=H:\Archivos de programa\DVD-RB PRO\Encoders\EclPro\EclPro.exe
DECOMB=H:\Archivos de programa\AviSynth 2.5\plugins\Decomb521.dll
NICAUDIO=H:\Archivos de programa\AviSynth 2.5\plugins\nicaudio.dll
MPEG2DEC=H:\Archivos de programa\DVD-RB PRO\DGDecode.dll
Working=Z:\
Output=J:\FILM\
CCENew=H:\Archivos de programa\Custom Technology\Cinema Craft Encoder SP2\ccew.exe
Source=Q:\FILM\VIDEO_TS\
[Audio]
Selected=10110000
Remapping=
[Subpictures]
Selected=11100000000000000000000000000000
[CCEOptions]
VBR_bias=25
Quality_prec=16
eclPasses=5
DVD rebuilder pro is 1.26.6 version
I would appreciate some help.
Thank you in advance.
Greets,
You could try un-installing them both then re-install CCE before DVD-RB again. Just to see if DVD-RB makes the correct setup linking. I remember seeing a problem like yours asked / answered before. Just cannot recall the remedy.
I have not used the CCE SP2 release. Frankly I have not used CCE since HCenc offered better SMP support with ver .022. In fact I would suggest you do give HCenc a try. You may become like I have and prefer it to CCE. It loves my Q6600, hope you enjoy yours as well. I feel HCenc is every bit on par with CCE in quality in addition to being faster. Even believe there may be a .023 out recently. I have not messed with it much since I started playing with x264 the last month or so.
Also, you may wish to try seeking your answer in the Doom9.org forum site. There is a subforum just for DVD-RB and the author jdobbs is quite responsive to answering questions. I suggest a search of that site first. The locals can take unkindly to questions that have been asked and answered a few times already. Good luck.
On second thought... if you are using the same v2.70 Basic that I bought for about $40 (?) years ago - that is not SP2. I think the new SP2 start out at v1.x whatever. In that case you want to have DVD-RB set to SP Basic, SP Trial, SP... one of those. Sorry, I do not have CCE installed since my last reformat. You may be getting your SP version names mixed up - an easy thing to do.
Cheers,
RickRene: Could you not just wound him a little bit?
Hans: Well now, with a 25 pound shell that is not easy.
'Allo 'Allo -
Thanks a lot for answering.
You gave me a clue. I have both CCEs in my computer, the 2.70 and the SP2, and I made a silly mistake mixing up the selection in the settings.
Now I have selected use CCE SP2Trial (Beta test) and it worked.
I´m thinking of giving HCenc a try. Thank you. I'll have though to get some information about this program before. How does it work etc.
BD Rebuilder new version problem
By fazza8 in forum Blu-ray RippingReplies: 5Last Post: 20th Aug 2009, 06:36 -
Premiere Pro CS3 unable to edit HDV??? (not trial version)
By Digipat in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 9th Feb 2008, 23:12 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 04:20 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 11:56
