when i burn onto a dual layer dvd disc there is major freezing of the movie between the two layers how can i prevent this
1) Use better media. If you aren't using Verbatim DVD+R DL discs, you wasted your money.
2) Burn with ImgBurn (it's free, so you have no excuse).
3) Buy another DVD player as with some models, even if you do #1 and #2 you won't be able to stop this. I've even seen some players that will freeze on the layer change with commercially pressed discs. -
What model DVD burner do you have? I have a Pioneer DVR-115D exclusively for double layer DVD burning. Best $35 ever invested.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Formatting dual layer DVDs before recording?
By Emmabarn in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2009, 23:10 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
Recording on a Dual Layer DVD 8x
By Avto in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2007, 13:55
