or it is completely different from standard dvd players?
Results 1 to 9 of 9
All monitors(CRT & LCD) display progressive,the way they deinterlace depends on the software.
what do u mean "the way they deinterlace depends on the software"?
and which dvd software can play progressive scan dvd? -
SD DVDs that are encoded as 23.976 fps with pulldown can be displayed as progressive by playing the disc at 23.976 without pulldown (i.e. the original progressive encoding). Anything encoded at 29.970 fps will be interlaced.
When you get to PAL it is even more confusing because PAL is encoded at 25 fps interlaced, even if it is progressive.Read my blog here.
Will a progressive scan MPEG2 work on all DVD Players?
By jnms in forum Authoring (DVD)Replies: 29Last Post: 30th Oct 2011, 17:22 -
BD/DVD Interlace vs Progressive Scan: Which is better?
By Bonie81 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2010, 07:01 -
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 13:52 -
Pioneer dvd - dv 393 progressive scan locked in
By kbm in forum DVD RippingReplies: 7Last Post: 27th May 2007, 01:39 -
Creating DVD for progressive scan DVDplayer/TV
By halsboss in forum Authoring (DVD)Replies: 1Last Post: 18th May 2007, 20:58
