Hi,
I have checked the option for Alcohol to mount the images on system start, but it doesn't work. I always have to remount them manually and I'm tired of it.
I also had a look at the auto-start applications on windows startup and saw that axcmd.exe alcohol automount is checked. So I don't understand it.
I would appreciate some help. Thanks in advance.
Assuming you have a registered version, have you contacted Alcohol? Their tech support is typically very helpful and quick to respond. Aside from that, I don't know what to tell you. If I mount an image, it stays mounted until I unmount it, even after multiple reboots and I don't recall changing any of the default settings after install.
Google is your Friend
Are there desk mounting clamps for hdtvs? Not wall mounting but a flat base
By yoda313 in forum Newbie / General discussionsReplies: 12Last Post: 2nd Oct 2011, 19:24 -
Mounting virtual images under Windows 7
By uniks in forum Newbie / General discussionsReplies: 6Last Post: 16th Jan 2010, 01:50 -
Variable frame rate (vfr) and 120 (119.88) fps video playback big problem
By lovyagin in forum Software PlayingReplies: 0Last Post: 22nd May 2009, 05:40 -
Alcohol 120%
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2009, 13:59 -
Alcohol 120% files into a DVD5
By P T Wheatstraw in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2009, 23:16
