I am helping a buddy transfer some minidv footage to Sony Vegas 8. I am transfering via a panasonic pvgs320 using the usb cable to input the avi files into vegas. Apparently the last time we did this the video went through fine, but instead of capturing the audio it recorded the conversation we were having. I am perplexed. Any idea as to why that happened or how to fix it? Thanks.
Most camcorders default to webcam mode when USB is used. In webcam mode you get low quality video (usually 352x240 CIF) and audio from the mic. The ones that I've used usually switch to tape audio when a tape is played. I can't explain why you get the mic. Must be a setting for voiceover.
If you want to transfer the high quality 720x480i DV video, you would use IEEE-1394. A limited set of camcorders do the latter over USB2 but only with proprietary software and drivers supplied with the camcorder. Consult the manual.
PS: It appears this model supports quality transfer over USB2 if you install the Panasonic drivers and the capture program from the CD. You would then import the resulting DV-AVI file from the hard disk into Vegas. Vegas DV capture only works with IEEE-1394. If it sees USB, it would be the webcam format.
http://www.bhphotovideo.com/c/product/477103-REG/Panasonic_PVGS320_PV_GS320_3_CCD_Mini.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
ok thanks for the advice. Yes my first preference is to use firewire, my friend's pc only has usb ports. I'll have to check into the drivers you're talking about, thanks both for the advice.
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
Capturing from MiniDV Cam & Audio simultaneously...
By gtrgriff3 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Aug 2008, 19:56 -
Sony Vegas 6 Audio
By Sunshine3012 in forum DVD RippingReplies: 2Last Post: 25th Oct 2007, 23:32 -
sony vegas audio
By romik91 in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2007, 16:37 -
AUDIO in SONY VEGAS 7.0?
By SeeNoEVO in forum EditingReplies: 3Last Post: 13th Jun 2007, 02:26
