Hello,
I hope someone can help with this.
I use a standalone Mini-DVC VCR. It has audio dubbing features. I use it to try and improve audio on old music videos, mainly Beatles :O)
When I am done inserting and synching new audio, I now have 2 seperate audio tracks on the DVC tape called "audio1" and "audio2" I can then playback the original audio or the new (dubbed) audio. All great until I try and transfer the work to my PC using Firewire. I open up Sony Vegas pro 8 and go to capture, then bingo I can see the video and hear the sound from "audio1" only. It gives me no option of selecting "audio2" or even better capturing both audio tracks at the same time. I don't want to Mix the two tracks, I want to import both sets of audio with the video, or at least be able to select audio 1 or 2. I tyred selecting the output on the DVC VCR, but when you use firewire your options are limited.
Thanks in advance for any help
J
Most DV decks or camcorders have a switch or mix control in the menus. You will need a separate capture pass for the second audio track. If all you have is a mix control, set it to 100% audio 1 for the first pass and 100% audio 2 for the second.Originally Posted by Jerry1964
Some consumer decks are limited to audio 1 over IEEE-1394. In that case, you would cap audio2 from the analog connectors.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks for the fast reply. Ok I understand you can't transfer both audio 1 and 2 at the same time(via firewire), but when using capture software, it should give you the choice between the two. I have a stand-alone Sony DVD recorder, and when you connect a camcorder to it, it has a drop-down menu with the option of recording audio 1 or 2 with the firewire!. This way you can get a digital transfer of either audio track. It has to be a software issue, since it worked with these two pieces of hardware. Anyone have capture software that allows you to choose what audio track you want to capture via firewire. I find it hard to believe the stand-alone sony has more capture options than $1000.00 software??
J
How To capture video shot in both sp and lp on the same dvc
By ishwinderjauhar in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2011, 09:40 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 14:34 -
Virtual Dubb giving me 4 GB output from 40 meg file
By illpeeonu in forum DVD RippingReplies: 4Last Post: 6th May 2007, 18:23
