Hey folks,
Quick and dirty question for you.
I burn a scad (southern for "a bunch") of audio CDs. For years I used Roxio's burning engine, but find the newer builds to be...well...not so good. And, I can't use my older, more reliable version on my A/V computer build (it doesn't see my DVD burners).
I'm looking for the engine that does for audio CDs what IMGBurn does for DVDs.
Any suggestions are appreciated.
Thanks a lot.
Results 1 to 14 of 14
I use Musicmatch Jukebox 7.5. I Won't use anything newer.
For just doing a disc to disc copy, Nero works fine. -
cd architect - not free but produces red book compliant cds.
http://www.feurio.com/English/index.shtml for me. There really isn't anything that compares to this short of costly professional software. Supports CD-text, track editing, flags, index markers (does anyone use these any more?), ISRC/UPC, user defined pauses, etc. It's shareware, but the trial version isn't limited in any way and you're bound by the honor system to send in your $29.
Feurio is a great application, but it may not work/recognize todays burners. I used to use it all the time and loved it. About a year ago, I downloaded it again and couldn't get it to work correctly easily. Both my LiteOn DVD burners were recognized, but the drivers Feurio uses are way outdated. I had to really tweak it to get it to work.
-The Mang -
While it's true Feurio could use some updated drivers, it does have a selection of generic drivers available if you click the INFO button next to the burner name, then driver > select driver. If Feurio gives you a "driver unsuitable" message then try each of the generic drivers in simulated burn mode till you find one that works. Usually one of them will work with most any burner. Feurio is still the best audio CD writer considering it's features, despite it driver issues sometimes.
Ashampoo Burning Studio 6 is free and supposedly very good. I've only used it a little but it seems to work very much like Nero.
Formerly: I used burnatonce for CDs, DVDdecrypter for DVDs.
Anymore (thanks LightninUK): Imgburn for Audio CDs, DVDs (both image and folder), file folders, etc.. It'll burn just about anything - with few if any errors.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Oh yeah; I forgot! The newest version of ImgBurn does audio CDs too. Let us know how well that works. I may not need cdrtfe anymore...
I just used ImgBurn today to copy an audio CD. The cuesheet it produced was a standard CDRwin cuesheet, complete with CD text. It was clear to me that I would be using ImgBurn from now on for burning audio CDs (as well as copying them). Formerly, I used "Burrrn" which worked, but was very picky about the cuesheet.
Darryl
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 14:38 -
Do you still play your physical Audio CDs?
By Baldrick in forum PollsReplies: 43Last Post: 4th Jan 2010, 01:02 -
Can't play audio CDs (.cda)
By kapow85 in forum ComputerReplies: 8Last Post: 1st Oct 2008, 04:47 -
AIFF files - burning quick audio CDs
By submerge in forum ffmpegX general discussionReplies: 4Last Post: 19th May 2008, 14:40 -
Help with DTS 5.1 Audio CDs
By ontherocks in forum AudioReplies: 4Last Post: 20th Aug 2007, 08:22
