I just formatted my MP4 player, how do I recover all my lost videos, music and pictures etc? Can anyone recommend a freeware please, I downloaded one earlier but no luck![]()
if you did a full format - you are not likely to get them back. if it was a quick format something like recover my files might work. as for free ones you'll have to search.
i went on windows media player and selected format from the list, it was most likely a quick format, my MP3 player doesn't come up on any hard drive or drive list for any of these recovery tools for some reason
What is the specific make and model of your player?
Which freeware did you already try? No point in recommending Flobo, for instance, if you already know it doesn't work in this case.
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
My MP4 player is the Samsung YP-P2JCM using the current 4.13 firmware.
I have tried quite a bit of them including some trialware, have used Flobo, Recuva and some others, since none worked, I just left it, and re-synced my music and I will re-convert my videos again soon. -
http://www.pcinspector.de/Sites/file_recovery/info.htm?language=1
PC Inspector Smart Recovery is the best free program that I've found - and likely rare by being entirely FREE.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
MP4 (AVC) Recover after SD filled up and all headers or footer corrupted.
By Bunkah in forum Newbie / General discussionsReplies: 1Last Post: 25th Feb 2011, 12:09 -
MP4 files on DVD player
By jimbauer in forum Newbie / General discussionsReplies: 1Last Post: 12th Feb 2011, 11:08 -
Best free player for mp4 files
By gary153 in forum Newbie / General discussionsReplies: 4Last Post: 27th Oct 2010, 17:56 -
How Can I recover a .mp4 File?
By PUCH84 in forum Video ConversionReplies: 0Last Post: 25th Aug 2009, 17:46 -
Recover MP4-files
By Mållgan in forum Newbie / General discussionsReplies: 5Last Post: 18th Jun 2009, 14:38
