Hi I have 2 conversion programmes that work fine upto now, my problem is I bought a Disney DVD at the weekend to shrink down to put on my Ipod, like I have done with all my other DVDs that I have bought, but I think Disney have hidden the movie on the disc. My programmes pick up everything else, e.g. trailers etc but not the movie, can someone please tell me what I need to do to make the movie title visible. The 2 programmes I use are Visual Hub and DVD to Ipod Converter on a MAC OSX.
use dvdfab decrypter to extract the movie only to the hard drive before trying to convert.
edit - sorry i didn't notice you are on a mac, use whatever is available that does the job on a mac.--
How about ripping your DVD with MactheRipper and choosing the option 'Main Feature Extraction'. That should give you a VIDEO_TS folder containing only the feature film and none of the extra's.
Disney tends to use more advanced -- and more troublesome -- encryption/authoring techniques than other studios. As Levina suggests, try Mactheripper. If the older, free version does not work, then try the newest version (not free, but inexpensive). Register at ripdifferent.com
http://www.ripdifferent.com/phpbb2/login.php?redirect=viewforum.php&f=26&start=0&sid=e...1e9216ec11b5f3
and then go from there.
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 19:46 -
trouble with audio after appending a .jpg turned .mp4 to another .mp4
By canadianjameson in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2011, 09:55 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 04:53 -
loop mp4 or avi locally so will play on mp4 player - ?
By marinebc11 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 20:24 -
Converting to PS3 .mp4 with MP4 Converter on Mac
By The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 21:24
